Sākumlapa › Forumi › Notepad.lv › IT ziņas › Android 4.3 noplūdis internetā un uzstādāms Nexus 4
Pirms dažām nedēļām tāpat noplūda Samsung Galaxy S4 paredzētais Android 4.3. Nekādu īpašu sūdzību nebija, bet tomēr nav garantijas, ka šīs ir galaversijas. Tāpēc iesaka neriskēt, nedaudz paciesties un saņemt oficiālos buildus
Kas jauns Android 4.3?
Informācija no avota
* Even when you turn off WiFi, it’ll stay on a bit in the background to help with location services — unless you dig even deeper into the advanced settings to really turn it off.
* There’s support for OpenGL ES 3.0 3D graphics.
* Bluetooth Low Energy is now supported, allowing for wireless, short-range communications with certain devices (like smartwatches) while using less power.
* There are a few new developer options for testing/debugging.
* The default “Roboto†font has been updated. Android Police has an analysis of the new font, as well as download links for folks that want to install it on devices that aren’t yet running Android 4.3.
* Third-party Android 4.3 apps may be able to totally replace the default notification system. Hello Facebook Home?
* It looks like you may have an option in the default Android 4.3 app drawer to sort apps and widgets by frequency of use. Right now apps can only be sorted alphabetically.
* When pairing with a car stereo over Bluetooth, your mobile device can now send song info to your car audio system.
* There’s support for T9 dialing in the phone dialer.
* Google has fixed the vulnerability known as the “Master Key†exploit.
* Google Keep is now a system app.
* Camera icons rotate when you turn the phone, while the overall camera app UI stays in place.
* Use the volume keys to snap photos in the camera app.
