Sākumlapa › Forumi › Notepad.lv › IT ziņas › Ar Android 5.1 izlabo daudzas "Lollipop" kļūdas
Android One
Pirmais, kas iekrīt acīs – atdots atpakaļ klasiskais Silent
* Silent mode added after missing on Android 5.0
* General improvements in system stability
* Improved RAM management
* Fixes for sudden app closures
* Improved battery management
* Excessive consumption of network devices when used Wi-Fi fixed
* Issues with wireless connections fixed
* Problems with Okay Google function solved
* Notifications problems solved
* Some sound problems experience by certain devices fixed
* Other improvements and changes
* Changes in the Material Design color palette (after users complaints, possibly for a higher version though)
