CPU sSpec/OPN# nummurs / Help
Sākumlapa Forumi Hardware Pamatplates un CPU CPU sSpec/OPN# nummurs / Help
  • #161636
    Oxys
    Vai tam sSpec/OPN# ir nozīme?
    Jo slots un modelis saskan tikai ne šis nr.
    CPU ietu neskatoties uz to nr.?
    Paldies.
    [img]https://www.bildites.lv/images/05u8vor8z8vqku31was.jpg[/img]
    #322151
    Turpinot troļļot tu tikai kaitēsi tēta naudasmakam.
    #322152
    Oxys
    Beton, es nopietni.
    Priecīgus Ziemassvētkus.
    #322153
    vrt56
    Specification number, or S-spec number, is a five character code that uniquely identifies such CPU characteristics as core frequency, bus frequency, the size of level 2 cache, thermal design power, and so on… vairāk te
