Sākumlapa › Forumi › Software › Internets, P2P un Serveru programmatūra › Interneta problema..cmd pings iet.. browserii neiet
varbut kads zina kur varetu buut problema, ja piem nopingoju caur cmd googli, youtube sanemu visas 4 paketes atpakalj… b et browserii taas lapas neiet…
Iespejams taa ir provaidera vaina? jo man tgd te uk nets caur telefonu, un iespejams vins kko chakaree….
agraak man latvijaa bija lidziga problema ar latnet, bet tas bija sen atpakalj.. man liekas tur es mainiju gateway adresi vai kko taadu….
Ja pingo web lapas caur cmd rakstot domēna vārdu, tad DNS ir kārtībā. Paņem un raksti tracert notepad.lv un redzēsi kur apstājas, ja neapstājas, tad zini- proxy, vai ugunsmūris vai antivīrus bloķē tieši pārlūkus
2. Ja kaut kas atslēdzas tad vajag aiz modēma uzlkikty rūteri lai neaizlēdzas visslaik online jābūt
3. Man pašriezējam modēmam lampiņa mirgo ja tā izlēgsies tad Vakars atkal 1.
proxy kekshi nav.. ugunsmuri arii atsledzu, tas pats…
Izskatās apmēram šādi:
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a ‘#’ symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
