Sākumlapa › Forumi › Mājas lapu izstrāde › CMS un Dziņi › Problēma ar Joomla 1.6
Strict Standards: Non-static method LoginController::login() should not be called statically in *:xampphtdocsadministratorcomponentscom_loginadmin.login.php on line 21
Fatal error: Call to a member function login() on a non-object in *:xampphtdocsadministratorcomponentscom_loginadmin.login.php on line 64
ko darit
Esmu nonācis līdz vienam erroram nomainot xamp uz wamp:
šis izmet tikai:
Call Stack
# Time Memory Function Location
1 0.0003 390928 {main}( ) ..index.php:0
2 0.0459 4643216 JAdministrator->dispatch( ) ..index.php:47
3 0.0529 5502240 JComponentHelper::renderComponent( ) ..application.php:152
[color=red]4 0.0563 5614832 require_once( ‘F:wampwwwadministratorcomponentscom_loginadmin.login.php’ ) ..helper.php:152[/color]
5 0.0563 5615112 LoginController::login( ) ..admin.login.php:21
Problēma ar šo cik saprotu:
// Execute the component.
ob_start();
require_once $path;
$contents = ob_get_contents();
ob_end_clean();
Paldies Deriksx par palīdzību.
