Sony WALKMAN NWZ-B133
Sākumlapa Forumi Citas tēmas Sludinājumi Sony WALKMAN NWZ-B133
  • #158331
    arturs24
    Sony WALKMAN NWZ-B133 1gb charging through USB
    9 ls
    https://www.sony.lv/product/nws-b-series/nwz-b133
    NWZ-B133
    1GB (250 songs) funky design WALKMAN® mp3 player with flashing power LED. Direct USB connection, 3 minute quick charging and 16 hours battery life. One touch bass boost for thumping low-end sounds.
    1GB storage, 16 hours playback, USB, one touch bass
    Ultra portable USB
    The B Series Walkman® makes it easy to plug in, load up your favourite tracks and playback in great sound quality – all via USB. ZAPPINâ„¢ song search technology helps you find tunes, FM radio gives you loads more listening choice, and quick charge means you’re ready to go in minutes.
    22011323
