Telefons ar WM, Wi-Fi, GPS par nieka 70ls
Sākumlapa Forumi Sakaru tehnika Mobilie telefoni Telefons ar WM, Wi-Fi, GPS par nieka 70ls
  • #150680
    Creep
    https://www.dealextreme.com/details.dx/sku.25045
    Saaku apsveert shii telefona iegaadi. Gribeetu dzirdeet juusu domas un varbuut arii kaadam links noder un izdomaa pasuutiit.
    #229197
    Blakius
    No komentiem apakšā:
    “The original windows Mobile 6.1 is not really touchscreen-friendly and has an ugly and small virtual keyboard.
    ¤ It seems that there is a problem with the touch screen at the extreme right of it: the vertical line is really hard to use. You can feel it when you try to use the windows scroll bar. Little bit annoying, but not a big thing. “
    “-As this is a really powerfull phone, battery drains fast”
    “2) It has some failures in the touch screen (the PDA interprets touching in some points as if it were other point sometimes).
    3) The buttons are somewhat difficult to use (pressing the directional button upwards sometimes makes you press left & right too), but with the touch screen you will rarely use it.”
    Vienu brīdi arī metu aci uz viņu, bet pārdomāju .
    #229198
    Creep
    Tas, ka vienam indiviidam taa gadiijies, nenoziimee, ka visiem taa ir.
    Un par negliito WM: likshu virsuu SPB shellu, taakaa taa nebuutu probleema…
    Pogas, pielauju, tika spiestas ar ziilona pirkstiem (man taadu nav), taatad arii tas netrauceetu (taapat cik biezhi tad shamaas izmanto).
    P.S. Komentaarus un topikus apakshaa tam telefonam jau sen paarlasiiju…
    #229199
    Blakius
    mhh, atgādināt Mērfija likumu?
    #229200
    Creep
    Par skaadi nenaaktu… Vienkaarshi paaraak vilinoshs dariijums liekas…
    #229201
    Toms
    Izskatās labs. Pie tam GPS. Geocachingistu sapnis 😀
    #229202
    Blakius
    Kur tu GPS tur redzi?
    Edit: ja nu vienīgi vienā komentārā zemāk, dīvaini ka specifikācijā nav minēts..
    Bilžā vienā arī GPS zīmējās
    #229203
    Man būtu bail tādu pirkt… 🙁
    #229204
    Creep
    Visur iznemot specifikaaciju rakstaas, ka esot vinam GPS.
    Un daGreivi: es ar bishkin raustos, taapeec arii tika izveidots shis topiks…
    #229205
    Nav tādi jāpērk. Sabrūk gabalos pēc dažiem mēnešiem, ja vien nenēsā visur apkārt kastītē.
