Timezone errors!
Sākumlapa Forumi Mājas lapu izstrāde PHPBB Timezone errors!
  • #154526
    Kikiz
    Sveicināti Notepad.lv lietotāji/admini un citi jūzeri kas lieto phpbb forumu!
    Tātad nesen esmu sastapies ar kādu TimeZone erroru…
    [phpBB Debug] PHP Notice: in file /index.php on line 86: date() [function.date]: It is not safe to rely on the system’s timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected ‘Europe/Helsinki’ for ‘EEST/3.0/DST’ instead
    [phpBB Debug] PHP Notice: in file /index.php on line 86: getdate() [function.getdate]: It is not safe to rely on the system’s timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected ‘Europe/Helsinki’ for ‘EEST/3.0/DST’ instead
    Š is būs nogriezums… Angļu valoda nav mana stiprā puse,kāds varētu man palīdzēt novērst šo kļūdu?
    #273035
    zombijs
    ieliec reģinālajos parametros (GMT+02:00) Helsinki, Riga, Tallinn, kā arī lokācijas vietu norādi Latviju un un kļūdai vajadzētu pazust.
    #273036
    Kikiz
    Nekas nemainās :/!
