vajadzetu atboket lg u400 no irijas tikliem uz lv tikliem tiesi uz okarti
Sākumlapa Forumi Sakaru tehnika Mobilie telefoni vajadzetu atboket lg u400 no irijas tikliem uz lv tikliem tiesi uz okarti
  • #157308
    palidziet atbloket nenem nevienu lv karti
    imei:359286 00 006744 9
    sn:607kppb006744
    butu labi ja atbildetu man uz epast ([email protected])
    ja izdosies atboket es aizsutisu uz jusu kontu 5ls tas kurs bus palidzejis
    #291164
    Paņemam uz nomaksu telefonu un bliežam uz Īriju? Sapērkamies tur dotētos mazcenas un mūkam mājās?
    O tempora, o mores
    #291165
    How to Enter Unlock Codes on all other LG U400 Shine (2 codes needed):
    1:Insert the network SIM in the handset which works with the phone (from the locked carrier).
    2:Enter 2945#*88110#.
    3:The phone will then prompt ‘Unlock sim’. Press OK.
    4:The phone will then prompt ‘Network Unlock’. Press OK.
    5:The phone will then prompt- ‘Input Network Control Key’. Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code. If you received a 16 digit code, enter it. The phone will have space for it.
    6:It should give you the message: Success.
    7:Come back to the main screen and Enter 2945#*88110#.
    8:The phone will then prompt unlock sim. Press OK.
    9:The phone will then prompt Network Unlock/ Lock but if you scroll down
    10 :you will see a message Enter SP Lock. Enter SP Code.
    Then press OK.
    This solution don’t work for LG U400 from Irland !!!
    BR
    ERSA
    Seb
    https://forum.gsmhosting.com/vbb/archive/t-488015.html
    https://www.mobile2mobile.net/Unlock_codes/LG.html
    itkā nevienam nestrādā šīs metodes , un vai tev ir kāds unlcok code?
    pamēģini mož sanāks.
    pamēģini sadarboties ar google. baigi krutā lapa esot.
    #291166
    m2tv
    Procedūra strādā, tikai vajadzīgs unlock kods, kura useram parastajam protams nav.
    Stāsta ja sūta uz googli tad labais tonis esot definēt pareizos meklēšanas vārdus savādāk tāda plika diršana sanāk. Bezmaksas padoms:SS attiecīga sadaļa, zvans tās lietas pārzinātājiem, vai arī izmantot kādu no weba unlock saitiem (piemēram https://sim-unlock.net/sim-lock/5/Unlock_by_code_for_any_LG/). Tas protams nav bez maksas
