WYSIWYG Web Builder 5.05 ir klāt!
Sākumlapa Forumi Mājas lapu izstrāde Web veidošana un problēmas WYSIWYG Web Builder 5.05 ir klāt!
  • #146605
    Izskatās, ka šis ir neslikts risinājums tiem, kas grib masveidā štancēt web lapas…
    Eh man šodien slinkums tulkot priekš raksta, tāpēc iemetu forumā. :devil:
    Web Builder is a WYSIWYG (What-You-See-Is-What-You-Get) program used to create web pages. WYSIWYG means that the finished page will display exactly the way it was designed. The program generates HTML (HyperText Markup Language) tags while you point and click on desired functions; you can create a web page without learning HTML. Just drag and drop objects to the page position them ‘anywhere’ you want and when you’re finished publish it to your web server (using the build in Publish tool). Web Builder gives you full control over the content and layout of your web page.
    WYSIWYG Web Builder features:
    • No HTML knowledge needed!
    • Drag and drop objects from the toolbox on the page anywhere you like!
    • Site Management. Easily add, edit, clone and structure your web pages from a single file.
    • Customizable menus, toolbars, keyboard accelerators, dockable windows, tabs, autohide windows.
    • Form layout object to create forms, including actions, hidden fields etc.
    • Supports Form fields: Editbox, TextArea, Checkbox, Radiobutton, Combobox and Button.
    • Form Wizard to create form in 4 steps. Select from a dozen ready-to-use forms.
    • Rich text support: text object can contain different fonts, colors, links and sizes.
    • Custom HTML object to insert your own HTML or Javascripts.
    • ActiveX, JAVA, Flash, Windows Media player, Quicktime, Real Audio and other Plug-In support.
    • Publish your entire web site, a single page or a group of pages (to local drive or a web server) .
    • Built-in Photo Gallery maker, with lots of cool features like picture frames!
    • Built-in Banner maker.
    • Rollover images.
    • Bulleted Lists: Circle, Disc, Square, Numeric (1, 2, 3), Alpha (a, b, c) , Roman (I, II, III) and custom images.
    • Image maps.
    • Customize scrollbar colors for Microsoft Internet Explorer.
    • Navigation bars.
    • Tab Menus.
    • Slide Menus.
    • Ready-to-use Javascripts.
    • Template support. Already more than 100 templates available!
    • Insert Symbols (special characters).
    • Slide Show component .
    • Support for third-party add-ons, using the Web Builder Component Developers Kit.
    • Import existing HTML pages.
    • Hyperlink Style Sheet, to customize the colors/formatting of hyperlinks.
    • Built-in Popup support.
    • Show optional rulers and ruler guides.
    • Page transitions in Page Properties.
    • Inline Frame component (IFRAME).
    • Go menu: easily create a drop-down navigation menus.
    • Menubar: powerful menu script that can mimic complex menus found in popular GUI applications.
    • Shape object (Rectangle, Round rect, Ellipse, Diamond, Hexagon, Octagon, Parallelogram, Triangle,
    Trapezoid, Arrows, Flag, Flower, Heart, Signs, Stars, Talk Bubbles and much more!).
    • Embedded OLE component.
    • Master page object. This allows you to re-use objects from other pages (master page concept).
    • Layer Object for advanced layout possibilities.
    • Find/Replace for text objects.
    • Validation tools for form components: EditBox, Combobox and TextArea.
    • Rotation for shapes and images.
    • Properties Inspector for quick object manipulation.
    • Ability to group/ungroup objects.
    • Image tools: Contrast, Brightness, Hue/Saturation, Flip, Rotate, Resample, Crop and Stencils.
    • Image effects: GrayScale, Negative, Sepia, Blur, Soften, Sharpen, Noise, Emboss and more!
    • Drawing tools: Line, Line + Arrows, Scribble, Polygon, Curve and Closed Curve.
    • Photo gallery border styles/ photo frames.
    • Images, shapes and form controls have a new Events Page, to easily add actions to object events!
    • The PayPal eCommerce Tools are the quickest and easiest way to add eCommerce to your web site!
    • RSS Feed object with podcast option.
    • Blog with built-in RSS feed option.
    • Google compatible sitemap generator
    • and much much more!
    Changes in version 5.05:
    – Fixed: Events in text objects are lost during site manager updates.
    – Fixed: Events in table cell text not working.
    – Fixed: Linked files are not published for bulleted lists.
    – Fixed: Mosaic effect crashes if extreme high values are used.
    Kur dabūt? šite vai arī mājaslapā
    [img]https://img227.imageshack.us/img227/722/screenshot1pz2.jpg[/img]
    #176156
    Uzliku un nedaudz paspēlējos.
    Drausmas.
    Tas tikai apstiprināja frāzi “ja nesaproti, tad neaiztiec”. Programmas veidotais lapas kods ir vienkārši drausmīgs. Tā varbūt varēja rakstīt 1997ajā, bet ne mūsdienās.
    Programmas mērķauditorija : topošie botāniķi, kuriem lektors lie kuztaisīt mājaslapu par vīngliemežu sociālo uzvedību.
    #176157
    Thx, mefisto! Viss skaidrs! :devil:
