checking libgc version 6.4+... Segmentation fault (core dumped)
no
configure: error: libgc (the Boehm Conservative Collector) 6.4+, is needed to compile inkscape -- http://www.hpl.hp.com/personal/Hans_Boehm/gc
===> Script "configure" failed unexpectedly.
Please run the gnomelogalyzer, available from
"http://www.freebsd.org/gnome/gnomelogalyzer.sh", which will diagnose the
problem and suggest a solution. If - and only if - the gnomelogalyzer cannot
solve the problem, report the build failure to the FreeBSD GNOME team at
gnome@FreeBSD.org, and attach (a)
"/usr/ports/graphics/inkscape/work/inkscape-0.45.1/config.log", (b) the output
of the failed make command, and (c) the gnomelogalyzer output. Also, it might
be a good idea to provide an overview of all packages installed on your system
(i.e. an `ls /var/db/pkg`). Put your attachment up on any website,
copy-and-paste into http://freebsd-gnome.pastebin.com, or use send-pr(1) with
the attachment. Try to avoid sending any attachments to the mailing list
(gnome@FreeBSD.org), because attachments sent to FreeBSD mailing lists are
usually discarded by the mailing list software.
*** Error code 1
Stop in /usr/ports/graphics/inkscape.
novilku sho:
/gnomelogalyzer.sh
palaidu bet tas man saka. :
ka jaapalaizh no direktorijas kur tas ports vai kaut ko tamliidziigu .
paarkopeeju palaidu
un sanjeemu taadu atbildi:
# /usr/ports/graphics/inkscape/gnomelogalyzer.sh
Generating build log. Please wait... done.
The cause of your build failure is not known to gnomelogalyzer.sh. Before
e-mailing the build log to the FreeBSD GNOME team at freebsd-gnome@FreeBSD.org,
TRY EACH OF THE FOLLOWING:
* If you are generating your own logfile, make sure to generate it with
something similar to:
"make 2>&1 | tee /path/to/logfile" (sh/bash/ksh/zsh) or
"make |& tee /path/to/logfile" (csh/tcsh)
* Make sure your cvsup(1) configuration file specifies the 'ports-all'
collection
* Run cvsup(1) and attempt the build again
* Check /usr/ports/UPDATING for information pertinent to your build
failure
* 99% of the commonly reported build failures can be solved by
running "portupgrade -a"
* Read the FAQs at http://www.FreeBSD.org/gnome/
* Search the archives of freebsd-gnome@FreeBSD.org. Archives can be
searched at http://www.freebsd.org/gnome/index.html#search
If you have not performed each of the above suggestions, don't bother asking
for help. The chances are good that you'll simply be told to perform one of
the aforementioned steps.
tagad nesaprotu ko mantaalaak dariit???
kaa dabuut vinju virsuu?
vispaar kaads vareeeetu man populaari paskaidrot kaa tad iisti tikt pie papildus uzstaadijumiem ...
es vissu metu virsuu vienkaarshi ierakstot make install clean un viss...
varbuut tas ne vienmeer der?????
