Pie k
Atbildes: 2011
Pie k
Post no deivs001 » 16 Mar 2007, 01:25
Nu atkâjat savu PC detaïas. Varçs redzçt, kas populârâks.
Nitro
Atbildes: 487
Post no Nitro » 16 Mar 2007, 04:27
Eemm..nee!
Not this **** again...
zhagis
Atbildes: 186
Post no zhagis » 16 Mar 2007, 06:44
CPU tips DualCore Intel Core 2 Duo E6300, 1866 MHz (7 x 267)
Sistçmas plates nosaukums Asus P5VD2-X (4 PCI, 1 PCI-E x1, 1 PCI-E x16, 2 DDR2 DIMM, Audio, Gigabit LAN)
Sistçmas atmiòa 1024 MB (DDR2-533 DDR2 SDRAM)
Cietais diska SAMSUNG SP2504C (250 GB, 7200 RPM, SATA-II)
fatduude
Atbildes: 99
Atrodas: tepat
Post no fatduude » 16 Mar 2007, 12:22
paðlaik esu darbâ un te kaste ir:
cpu -intel pentium III 660mhz
ram - 248mb
vga - kaut kâds tur tridnet video accelerator blade 3d/promedia 8mb :)
hdd - samsung 20gb ide
os - winxp
cd drive - samsung kaut kâds tur
floppy - ..íipa ir :)
Atbildes: 2873
Post no usins » 16 Mar 2007, 12:29
Tâ mans datoriòð-
AMD Athlon XP 2000+ 1.66 GHz
Mainboard DFI AD 73 Pro- VGA, DDR, 5 PCI 2 IDE utt.
RAM- 2x256 MB
Video- gForse FX 5200
HDD- 60 GB kkaads, un Samsung 250 GB (tas dçï tâ . ka lietoju trakerus :D)
Skaòas karte- Integrçtâ AC`97.
Tas itkâ viss. Â moncis- Samtron 17'' 76DF
Pele- Samsung optiskâ, klaviatûra, kkâda ira..
Atbildes: 5080
Post no foxsk8 » 16 Mar 2007, 13:05
TheNewGuy wrote:ASUS A8V - EAYZ
BIOS: AMI
Chipset: VIA K8T800Pro + VT8237
CPU Interface: Socket 939
Max. CPU Support: AMD Sempron 3200+, AMD Athlon 64 4000+, AMD Athlon 64 FX-57, AMD Athlon X2 Dual-Core 4800+
Front Side Bus: 2000MT/s
RAM Technology: DDR (Dual Channel)
RAM Slots: 4 x 184-Pin
RAM Speeds: DDR266, DDR333, DDR400
Max. Memory Support: 4GB
Expansion Slots: 1 x AGP 8x/4x, 5 x 32-bit PCI, Storage Controller(s), 2 x IDE (ATA-133/100/66/33), 2 x Serial (ATA-150), RAID 0, RAID 1, JBOD
On-Board LAN : 1 x 10/100/1000
On-Board Audio: Realtek ALC850, 8-channel
On-Board Video
Back Panel I/O Ports: 1 x Parallel, 1 x COM, 1 x PS/2 Keyboard, 1 x PS/2 Mouse, 4 x USB2.0, 1 x Coaxial S/PDIF Output, 1 x LAN, 6 x Audio
Internal I/O Connectors: 2 x USB2.0, 3 x FAN, 1 x 20-pin ATX Power, 1 x 4 pin ATX 12V Power, 1 x CD Audio, 1 x AUX, 1 x Game
Form Factor: ATX, 305mm x 245mm
Special Features: AMD Cool 'n' Quiet Technology, AI NET, AI Audio
Package Contents: User's Manual, 2 x 1-port S-ATA Power Leads, 2 x S-ATA Data Leads, 2 x IDE Lead, 1 x Floppy Lead, Backplate, Driver CD
Cietais disks: 80 GB SATAII 7200 prm
Procesors: Sempron 2500+ ; 1,4 Ghz
Operatîvâ atmiòa 2X256 Mb DDRAM
CDROM: DVD-RW+- LiteOn. 16X Dual Layer
Pârejais:
Iebûvçta video karte - Geforce 6100 256MB
Baroðanas bloks: 300W
Avermedia TV karte
ExtrmeAir Plus bezvadu tîkla karte
Priekð servera vajadzîbâm pietiek.
2. Dators
CPU- 633 MHZ
HDD - 40 GB Samsung 5200 rpm
RAM - 256 MB SDRAM
Tîkls
Floppy
Mâtesplate mistiska :D
Video 16 MB integrçta
Skanâs karte - integrçta
3. Dators
Intel Celeron 2,4 Ghz
Mateni tagad nepateikðu
HDD - 200 GB SATAII
Video - Geforce 6100, 256 MB, 128 bit
TV karte
DVD-RW sîdis
Viss pârçjais kâ parasti
4. Dators (Portatîvais)
Dell
PIII 1000 Mhz
RAM - 256 MB
HDD - 20 GB
CDROM
Infrared
15 collu ekrâns
Tâka rakstîju visus, jo pie visiem sçþu, kad kâds cits ir aizòemts.
Atbildes: 2873
Post no usins » 16 Mar 2007, 13:13
:D nu gan.. fox :D
Atbildes: 5080
Post no foxsk8 » 16 Mar 2007, 14:41
Drîz varçðu datorsalonu atvçrt savçjiem :D
Atbildes: 2873
Post no usins » 16 Mar 2007, 15:17
:D
Atbildes: 1632
Post no Loading » 16 Mar 2007, 18:50
1. 1.8 Ghz Celeron, 256 DDRAM, GeForce MX 440 (64mb), 80 GB
2. 533 Mhz (PIII/Celeron), 64+64 SDRAM, 8 Mb video, 10,1 GB
3. 2.1 Ghz Celeron, 256+256 DDRAM, Radeon 9550 (256mb, 128bit), 80 + 200 GB
Mad182
Atbildes: 903
Post no Mad182 » 16 Mar 2007, 19:01
OS: Linux 2.6.17-11-386 | CPU: AMD Athlon(tm) @ 1595.636 MHz | MemTotal: 256160 kB | MemFree: 30328 kB | SwapTotal: 746980 kB | SwapFree: 666212 kB | Current RES: 1024x768 pixels (322x241 millimeters) | Video: Nvidia Gforce 440MX 64 MB | (eth0) Data Sent: 3985292 (3.8 MiB) | (eth0) Data Recivied: 20550786 (19.5 MiB) | Uptime: 18:55:24 up 3:50, 1 user, load average: 0.51, 0.43, 0.36
Vçl tur mçtâjas 40GB samsung hdd, 80 GB excelstor hdd, DVD-RW, CD-RW, CD-R.
Atbildes: 1632
Post no Loading » 16 Mar 2007, 19:11
Atbildes: 2873
Post no usins » 17 Mar 2007, 19:04
Loadingam dubultposts!!!!! :twisted: :D
normis_161
Atbildes: 436
Post no normis_161 » 24 Apr 2007, 21:59
Nja. Kâ es varçju tikt pie tâda datora... :hmz:
Video karte: 64 mb (iebuvçtâ);
Procesors: 2,4 GHz Celeron;
HDD: 80GB;
Ram: 256MB + 1GB DDR (vislabâkais, kas ir manam datoram);
p.s. var teikt, ka man ram velkkaut kâdas programmas bet procesors ne, bet sâkumâ bija otrâdâk, kad man bija 256 MB.
Atbildes: 1780
Post no Mr.Death » 24 Apr 2007, 22:00
80 GB HDD, 512 RAM, 64 MB Video, 1500 Mhz AMD Athlon. :die:
AIDSkillz
Atbildes: 183
Post no AIDSkillz » 24 Apr 2007, 23:28
ACPI Multiprocessor PC
Intel Pentium 4, 3600 MHz (15 x 240) (Stock 3GHz)
Gigabyte GA-8IPE1000-G
Intel Springdale i865PE
1024 MB (PC3200 DDR SDRAM Dual)
NVIDIA GeForce 6600 GT (128MB 128bit)
BenQ FP92E
Realtek ALC850 @ Intel 82801EB ICH5
Floppy disks
SAMSUNG SP0812C (80 GB, 7200 RPM, SATA)
LITE-ON DVDRW SOHW-1213S
ASUS 802.11g tikla adapteris
Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller
funusage
Atbildes: 8
Pievienojies: 25 Apr 2007, 16:00
Post no funusage » 25 Apr 2007, 16:35
Mans (jau pusgadu nolietotais) saldumiòð -
CPU :Athlon 4200+ X2 Dual Core
Memory : 2GB DDR2
Video : Geforce 7300 GT 512 MB
HDD : 250 GB Maxtor
Monitor : Nekas îpaðs (F730B Flatron`s)
DVD Rooms
Viss laikam :) pagaidâm man pilnîbâ viss apmierina ðajâ "zvçrâ" .
(Izmaksâja 660Ls , pirku Septembrî)
Ogijs
Atbildes: 32
Pievienojies: 29 Apr 2007, 08:17
Post no Ogijs » 29 Apr 2007, 19:15
Nekas spîdoðs.
AMD Sempron 2500+ 1.4 GHz @ clock 1.6 GHz
DDR400 512 MB Apacer RAM
GeForce 6600 GT 256 MB
80 GB ATA Samsung HDD
MB: Biostar K8VGA-M
Lite-On DVD-RW 16x
dzhonsons
Atbildes: 820
Post no dzhonsons » 29 Apr 2007, 20:16
Nekas spîdoðs.
AMD Athlon 3000+ 1.8 GHz
DDR2 512 MB RAM
GeForce 6150 GT 128 MB
80 GB SATA Samsung HDD
MB: Asus M2NPV-MX
Lite-On DVD-RW 16x
unse
Atbildes: 11
Pievienojies: 22 Apr 2007, 16:31
Post no unse » 29 Apr 2007, 20:33
krâniòu staipîðanas laiks :rofl: :rofl:
Usinja piebilde- nu nebût nç, varbût èalim vajag veidot statistiku kâdi PC bieþâk tiek lietoti. :hmz:
no_name
Atbildes: 17
Pievienojies: 29 Mar 2007, 22:42
Atrodas: Centrs
Post no no_name » 30 Apr 2007, 12:44
Product Name dv6103eu
Microprocessor Mobile AMD Sempron™ Processor 3400+
Microprocessor Cache Level 2 cache 256 KB
Memory 512 MB DDR2 667 MHz (1 x 512 MB)
Memory Max up to 2 GB
Video Graphics NVIDIA® GeForce™ Go 6150
Video Memory up to 128 MB (shared)
Hard Drive 80 GB 5400 rpm
Multimedia Drive Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
Display 15.4” WXGA High Definition BrightView Widescreen (1280 x 800)
Fax/Modem High speed 56K modem
Network Card Ethernet 10/100BT integrated network interface
Wireless Connectivity 802.11b/g WLAN
Sound Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard 101 key compatible keyboard
Pointing Device Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 1 Quick Launch Button
PC Card Slots One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports 1 VGA port
2 USB 2.0 ports
1 RJ 11 modem connector
1 RJ 45 Ethernet connector
S-video TV out
1 Headphone-out, 1 Microphone-in port
Cable docking connector
Dimensions 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H)
Weight 2.99 kg (6.6 lbs)
Power 65 W AC Power Adapter
6-cell Lithium-Ion (Li-Ion) battery
What's In The Box HP Mobile Remote Control
Operating System: Genuine Windows XP Home Edition
http://h10025.www1.hp.com/ewfrf/wc/gene ... R1002_USEN
Atbildes: 5311
Post no shady » 01 Mai 2007, 18:25
Pie strâdâjoða!
Ingemārs
Atbildes: 2
Pievienojies: 01 Mai 2007, 18:54
Post no Ingemārs » 01 Mai 2007, 20:31
AMD 2Ghz venice single core
MoBo: Abit fatal1ty an8 sli
2x maxtor 80Gb sata2
Creative sound blaster
geforce 7900Gt
2x kingston 512 ddr400
monitors:Proview flat 17"
Ja var�tu,tad uzceltu sev pieminekli,tikai nezinu �sti par ko.
Enrike
Atbildes: 14
Pievienojies: 05 Mai 2007, 10:32
Atrodas: Neumunde
Post no Enrike » 07 Mai 2007, 22:16
Maacplate: Abit NF7 S2G
Procesors: AMD Athlon XP 2200+@1,94Ghz
Atmiòa: 512Mb DDR400 (pagaidâm, bûs apgreids uz 2Gb)
80Gb HDD Seagate Barracuda sATA + 2x250 onTower (filmas un visaada citaada draza)
CD-RW/DVDRom
350W FSP
Flopiks, Bluetooth devaiss un citi siikumi
Ak jaa - videne 32Mb RivaTNT - speeles nespeeleeju - pilniibaa apmierina. Naaks vista, nomainiisju.
Iisumaa taads darba zirdzinjsj...
Idiotisms ir universāls, jo to nevar izmērīt nevienā no vispārpieņemtajām mērvienībām. Heidingers
