uzlauzt rar arhīvu
D3nY
Atbildes:31
Pievienojies:14:16 / 22. Jan, 2008
uzlauzt rar arhīvu
Post no D3nY » 23:27 / 3. Mar, 2008
ar kādu programu ir visefektīvāk un ātrāk uzlauzt rar arhīvu
Atbildes:14988
Atrodas:Liepājas anomālā zona
Post no samurajs » 23:33 / 3. Mar, 2008
Teorētiski - ar BruteForce. Praktiski parolētu rar atkost nav iespējams - Aleksandrs Rošāls par to ir parūpējies. Process var ievilkties gadiem.
memorex
Atbildes:836
Atrodas:Latvia
Post no memorex » 13:12 / 4. Mar, 2008
esmu mēģinājis atlauzt, bet nesekmīgi, varbūt izdotos ja zin cik parole gara (no kā sastāv: cipari, burti, ja abi kopā tad sliktāk)
Atbildes:979
Post no Sid » 16:20 / 4. Mar, 2008
samurajs wrote:Teorētiski - ar BruteForce. Praktiski parolētu rar atkost nav iespējams - Aleksandrs Rošāls par to ir parūpējies. Process var ievilkties gadiem.
VISU var uzlaust :)
Atbildes:14988
Post no samurajs » 16:55 / 4. Mar, 2008
Sid: ir viena laba programma: https://www.sharewareconnection.com/atom ... covery.htm
Lasām:
Atomic RAR Password Recovery is a software designed to restore the password for the archives created by WinRAR. Due to the structure of the RAR-file, encryption in RAR is quite strong, so the password can not be found instantly as it takes a lot of resources. The speed of the password search depends on the archive version. Password restoring procedure for RAR 2.xx archives is much faster then for the RAR 3.xx ones. Brute-force attack generates the list of passwords using all available symbols and checks them one-by-one. It's slow method, but only it can guarantee the password recovery. Brute-force attack can be used if your password is less than say 5 characters, otherwise, password recovery can take months! In fact, the longer your password is, the longer it takes (exponentially)! Hey! If your password is a known word (not name or so) then there is a way out. You should use Dictionary attack. This method could speed up things to about 1/2 an hour. You can get Dictionaries (word lists) on the Internet. Under the Dictionary attack all provided passwords are checked. Atomic RAR Password Cracker has a friendly user interface. It has a wizard which helps you to find the password in the fastest way. The program is able to save a current state (you can interrupt the program at any time, and restart from the same state later). Estimated time calculator allows you to configure the program more carefully.
Tātad 12345 vai sid vēl ir cerības atkost, bet šito - Tj8&bhruKlwe0%kaLp7 varēs kost 1.000.000 gadu :D
rajah
Atbildes:730
Atrodas:Leišmale
Post no rajah » 11:22 / 7. Mar, 2008
Tas gan mani interesē - vai nav iespējams uzzināt, cik liela ir tā parole - 3 vai 23 simboli?
Ja 23 - tad jau es uzreiz metu to failu prom.
Starp citu - iesaku:
https://dic.pp.ru/ Забытые пароли
vai tiem kam krievu valoda ne pārāk, angliski
https://dic.pp.ru/en/
Ja paroles failiem ir no kādām populārām vietā, šeit var ielādēt populārāko paroļu sarakstus un izmantot failu kā vārdnīcu faila laušanai. Man bija novilktas grāmatas no kādas lapas, kurām paroli aizmirsu, pār 2 gadiem paroles atradu.
Step By Step - ImageImage
Atbildes:5080
Atrodas:Liepāja
Post no foxsk8 » 11:39 / 7. Mar, 2008
Vai arī google meklēt pēc rar orģinālā faila nosaukuma. Varbūt izdodās ko atrast.
