Syntax ERROR!
Ernijs_E
Atbildes: 94
Pievienojies: 09 Mar 2008, 17:24
Atrodas: Rīga, Iecava
Syntax ERROR!
Post no Ernijs_E » 08 Apr 2008, 23:37
Sveiki.
Problēma ir tāda:
Es mēģināju pie PHPBB2 pielikt lejā čatu. Itkā visu izdarīju kā bija rakstīts moda instalācija, bet nu sartējot savu forumu izmet šādu paziņojumu:
Parse error: syntax error, unexpected ';', expecting ')' in C:\wamp\www\phpBB2\index.php on line 282
Vai kāds nevar palīdzēt? Ceru uz autsaucību.. :)
Code: Select all
<php>assign_vars&#40;array&#40;
		"META" => '<meta>'&#41;
	&#41;;
	$message = $lang&#91;'Forums_marked_read'&#93; . '<br><br>' . sprintf&#40;$lang&#91;'Click_return_index'&#93;, '<a>', '</a> '&#41;;
	message_die&#40;GENERAL_MESSAGE, $message&#41;;
&#125;
// End handle marking posts
$tracking_topics = &#40; isset&#40;$HTTP_COOKIE_VARS&#91;$board_config&#91;'cookie_name'&#93; . '_t'&#93;&#41; &#41; ? unserialize&#40;$HTTP_COOKIE_VARS&#91;$board_config&#91;'cookie_name'&#93; . "_t"&#93;&#41; &#58; array&#40;&#41;;
$tracking_forums = &#40; isset&#40;$HTTP_COOKIE_VARS&#91;$board_config&#91;'cookie_name'&#93; . '_f'&#93;&#41; &#41; ? unserialize&#40;$HTTP_COOKIE_VARS&#91;$board_config&#91;'cookie_name'&#93; . "_f"&#93;&#41; &#58; array&#40;&#41;;
// If you don't use these stats on your index you may want to consider
// removing them
$total_posts = get_db_stat&#40;'postcount'&#41;;
$total_users = get_db_stat&#40;'usercount'&#41;;
$newest_userdata = get_db_stat&#40;'newestuser'&#41;;
$newest_user = $newest_userdata&#91;'username'&#93;;
$newest_uid = $newest_userdata&#91;'user_id'&#93;;
if&#40; $total_posts == 0 &#41;
&#123;
	$l_total_post_s = $lang&#91;'Posted_articles_zero_total'&#93;;
&#125;
else if&#40; $total_posts == 1 &#41;
&#123;
	$l_total_post_s = $lang&#91;'Posted_article_total'&#93;;
&#125;
else
&#123;
	$l_total_post_s = $lang&#91;'Posted_articles_total'&#93;;
&#125;
if&#40; $total_users == 0 &#41;
&#123;
	$l_total_user_s = $lang&#91;'Registered_users_zero_total'&#93;;
&#125;
else if&#40; $total_users == 1 &#41;
&#123;
	$l_total_user_s = $lang&#91;'Registered_user_total'&#93;;
&#125;
else
&#123;
	$l_total_user_s = $lang&#91;'Registered_users_total'&#93;;
&#125;
// Start page proper
$sql = "SELECT c.cat_id, c.cat_title, c.cat_order
	FROM " . CATEGORIES_TABLE . " c
	ORDER BY c.cat_order";
if&#40; !&#40;$result = $db->sql_query&#40;$sql&#41;&#41; &#41;
&#123;
	message_die&#40;GENERAL_ERROR, 'Could not query categories list', '', __LINE__, __FILE__, $sql&#41;;
&#125;
$category_rows = array&#40;&#41;;
while &#40;$row = $db->sql_fetchrow&#40;$result&#41;&#41;
&#123;
	$category_rows&#91;&#93; = $row;
&#125;
$db->sql_freeresult&#40;$result&#41;;
if&#40; &#40; $total_categories = count&#40;$category_rows&#41; &#41; &#41;
&#123;
	// Define appropriate SQL
	switch&#40;SQL_LAYER&#41;
	&#123;
		case 'postgresql'&#58;
			$sql = "SELECT f.*, p.post_time, p.post_username, u.username, u.user_id
				FROM " . FORUMS_TABLE . " f, " . POSTS_TABLE . " p, " . USERS_TABLE . " u
				WHERE p.post_id = f.forum_last_post_id
					AND u.user_id = p.poster_id
					UNION &#40;
						SELECT f.*, NULL, NULL, NULL, NULL
						WHERE NOT EXISTS &#40;
							SELECT p.post_time
							FROM " . POSTS_TABLE . " p
						&#41;
					&#41;
					ORDER BY cat_id, forum_order";
			break;
		case 'oracle'&#58;
				WHERE p.post_id = f.forum_last_post_id&#40;+&#41;
					AND u.user_id = p.poster_id&#40;+&#41;
				ORDER BY f.cat_id, f.forum_order";
			break;
		default&#58;
				FROM &#40;&#40; " . FORUMS_TABLE . " f
				LEFT JOIN " . POSTS_TABLE . " p ON p.post_id = f.forum_last_post_id &#41;
				LEFT JOIN " . USERS_TABLE . " u ON u.user_id = p.poster_id &#41;
			break;
	&#125;
	if &#40; !&#40;$result = $db->sql_query&#40;$sql&#41;&#41; &#41;
	&#123;
		message_die&#40;GENERAL_ERROR, 'Could not query forums information', '', __LINE__, __FILE__, $sql&#41;;
	&#125;
	$forum_data = array&#40;&#41;;
	while&#40; $row = $db->sql_fetchrow&#40;$result&#41; &#41;
	&#123;
		$forum_data&#91;&#93; = $row;
	&#125;
	if &#40; !&#40;$total_forums = count&#40;$forum_data&#41;&#41; &#41;
	&#123;
		message_die&#40;GENERAL_MESSAGE, $lang&#91;'No_forums'&#93;&#41;;
	&#125;
	// Obtain a list of topic ids which contain
	// posts made since user last visited
	if &#40;$userdata&#91;'session_logged_in'&#93;&#41;
	&#123;
		// 60 days limit
		if &#40;$userdata&#91;'user_lastvisit'&#93; <time>sql_query&#40;$sql&#41;&#41; &#41;
		&#123;
			message_die&#40;GENERAL_ERROR, 'Could not query new topic information', '', __LINE__, __FILE__, $sql&#41;;
		&#125;
		$new_topic_data = array&#40;&#41;;
		while&#40; $topic_data = $db->sql_fetchrow&#40;$result&#41; &#41;
		&#123;
			$new_topic_data&#91;$topic_data&#91;'forum_id'&#93;&#93;&#91;$topic_data&#91;'topic_id'&#93;&#93; = $topic_data&#91;'post_time'&#93;;
		&#125;
	&#125;
	// Obtain list of moderators of each forum
	// First users, then groups ... broken into two queries
	$sql = "SELECT aa.forum_id, u.user_id, u.username
		FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug, " . GROUPS_TABLE . " g, " . USERS_TABLE . " u
		WHERE aa.auth_mod = " . TRUE . "
			AND g.group_single_user = 1
			AND ug.group_id = aa.group_id
			AND g.group_id = aa.group_id
			AND u.user_id = ug.user_id
		GROUP BY u.user_id, u.username, aa.forum_id
		ORDER BY aa.forum_id, u.user_id";
	&#123;
		message_die&#40;GENERAL_ERROR, 'Could not query forum moderator information', '', __LINE__, __FILE__, $sql&#41;;
	&#125;
	$forum_moderators = array&#40;&#41;;
	&#123;
		$forum_moderators&#91;$row&#91;'forum_id'&#93;&#93;&#91;&#93; = '<a>' . $row&#91;'username'&#93; . '</a>';
	&#125;
	$sql = "SELECT aa.forum_id, g.group_id, g.group_name
			AND g.group_single_user = 0
			AND g.group_type <GROUP_HIDDEN>sql_query&#40;$sql&#41;&#41; &#41;
	&#123;
	&#125;
	&#123;
		$forum_moderators&#91;$row&#91;'forum_id'&#93;&#93;&#91;&#93; = '<a>' . $row&#91;'group_name'&#93; . '</a>';
	&#125;
	// Find which forums are visible for this user
	$is_auth_ary = array&#40;&#41;;
	$is_auth_ary = auth&#40;AUTH_VIEW, AUTH_LIST_ALL, $userdata, $forum_data&#41;;
	// Start output of page
	define&#40;'SHOW_ONLINE', true&#41;;
	$page_title = $lang&#91;'Index'&#93;;
	include&#40;$phpbb_root_path . 'includes/page_header.'.$phpEx&#41;;
	$template->set_filenames&#40;array&#40;
		'body' => 'index_body.tpl'&#41;
	&#41;;
	$template->assign_vars&#40;array&#40;
		'TOTAL_POSTS' => sprintf&#40;$l_total_post_s, $total_posts&#41;,
		'TOTAL_USERS' => sprintf&#40;$l_total_user_s, $total_users&#41;,
		'NEWEST_USER' => sprintf&#40;$lang&#91;'Newest_user'&#93;, '<a>', $newest_user, '</a>'&#41;,
// ChatBox Mod
	require_once&#40;$phpbb_root_path . 'chatbox_front.php'&#41;;
		'FORUM_IMG' => $images&#91;'forum'&#93;,
		'FORUM_NEW_IMG' => $images&#91;'forum_new'&#93;,
		'FORUM_LOCKED_IMG' => $images&#91;'forum_locked'&#93;,
		'L_FORUM' => $lang&#91;'Forum'&#93;,
		'L_TOPICS' => $lang&#91;'Topics'&#93;,
		'L_REPLIES' => $lang&#91;'Replies'&#93;,
		'L_VIEWS' => $lang&#91;'Views'&#93;,
		'L_POSTS' => $lang&#91;'Posts'&#93;,
		'L_LASTPOST' => $lang&#91;'Last_Post'&#93;,
		'L_NO_NEW_POSTS' => $lang&#91;'No_new_posts'&#93;,
		'L_NEW_POSTS' => $lang&#91;'New_posts'&#93;,
		'L_NO_NEW_POSTS_LOCKED' => $lang&#91;'No_new_posts_locked'&#93;,
		'L_NEW_POSTS_LOCKED' => $lang&#91;'New_posts_locked'&#93;,
		'L_ONLINE_EXPLAIN' => $lang&#91;'Online_explain'&#93;,
		'L_MODERATOR' => $lang&#91;'Moderators'&#93;,
		'L_FORUM_LOCKED' => $lang&#91;'Forum_is_locked'&#93;,
		'L_MARK_FORUMS_READ' => $lang&#91;'Mark_all_forums'&#93;,
// ChatBox Mod
		'TOTAL_CHATTERS_ONLINE' => sprintf&#40;$lang&#91;'How_Many_Chatters'&#93;, $howmanychat&#41;,
		'CHATTERS_LIST' => sprintf&#40;$lang&#91;'Who_Are_Chatting' &#93;, $chatters&#41;,
		'L_CLICK_TO_JOIN_CHAT' => $lang&#91;'Click_to_join_chat'&#93;,
		'S_JOIN_CHAT' => append_sid&#40;"chatbox_mod/chatbox.$phpEx"&#41;,
		'CHATBOX_NAME' => $userdata&#91;'user_id'&#93; . '_ChatBox', // To make easier to test on my PC
		'L_LOGIN_TO_JOIN_CHAT' => $lang&#91;'Login_to_join_chat'&#93;,
		'U_MARK_READ' => append_sid&#40;"index.$phpEx?mark=forums"&#41;&#41;
	&#41;;
	// Let's decide which categories we should display
	$display_categories = array&#40;&#41;;
	for &#40;$i = 0; $i < $total_forums; $i++ &#41;
	&#123;
		if &#40;$is_auth_ary&#91;$forum_data&#91;$i&#93;&#91;'forum_id'&#93;&#93;&#91;'auth_view'&#93;&#41;
		&#123;
			$display_categories&#91;$forum_data&#91;$i&#93;&#91;'cat_id'&#93;&#93; = true;
		&#125;
	&#125;
	// Okay, let's build the index
	for&#40;$i = 0; $i <total_categories>assign_block_vars&#40;'catrow', array&#40;
				'CAT_ID' => $cat_id,
				'CAT_DESC' => $category_rows&#91;$i&#93;&#91;'cat_title'&#93;,
				'U_VIEWCAT' => append_sid&#40;"index.$phpEx?" . POST_CAT_URL . "=$cat_id"&#41;&#41;
			&#41;;
			if &#40; $viewcat == $cat_id || $viewcat == -1 &#41;
			&#123;
				for&#40;$j = 0; $j < $total_forums; $j++&#41;
				&#123;
					if &#40; $forum_data&#91;$j&#93;&#91;'cat_id'&#93; == $cat_id &#41;
					&#123;
						$forum_id = $forum_data&#91;$j&#93;&#91;'forum_id'&#93;;
						if &#40; $is_auth_ary&#91;$forum_id&#93;&#91;'auth_view'&#93; &#41;
						&#123;
							if &#40; $forum_data&#91;$j&#93;&#91;'forum_status'&#93; == FORUM_LOCKED &#41;
							&#123;
								$folder_image = $images&#91;'forum_locked'&#93;;
								$folder_alt = $lang&#91;'Forum_locked'&#93;;
							&#125;
							else
							&#123;
								$unread_topics = false;
								if &#40; $userdata&#91;'session_logged_in'&#93; &#41;
								&#123;
									if &#40; !empty&#40;$new_topic_data&#91;$forum_id&#93;&#41; &#41;
									&#123;
										$forum_last_post_time = 0;
										while&#40; list&#40;$check_topic_id, $check_post_time&#41; = @each&#40;$new_topic_data&#91;$forum_id&#93;&#41; &#41;
										&#123;
											if &#40; empty&#40;$tracking_topics&#91;$check_topic_id&#93;&#41; &#41;
											&#123;
												$unread_topics = true;
												$forum_last_post_time = max&#40;$check_post_time, $forum_last_post_time&#41;;
											&#125;
											else
											&#123;
												if &#40; $tracking_topics&#91;$check_topic_id&#93; <check_post_time> $forum_last_post_time &#41;
											&#123;
											&#125;
										&#125;
										if &#40; isset&#40;$HTTP_COOKIE_VARS&#91;$board_config&#91;'cookie_name'&#93; . '_f_all'&#93;&#41; &#41;
										&#123;
											if &#40; $HTTP_COOKIE_VARS&#91;$board_config&#91;'cookie_name'&#93; . '_f_all'&#93; > $forum_last_post_time &#41;
											&#123;
											&#125;
										&#125;
									&#125;
								&#125;
								$folder_image = &#40; $unread_topics &#41; ? $images&#91;'forum_new'&#93; &#58; $images&#91;'forum'&#93;;
								$folder_alt = &#40; $unread_topics &#41; ? $lang&#91;'New_posts'&#93; &#58; $lang&#91;'No_new_posts'&#93;;
							&#125;
							$posts = $forum_data&#91;$j&#93;&#91;'forum_posts'&#93;;
							$topics = $forum_data&#91;$j&#93;&#91;'forum_topics'&#93;;
							if &#40; $forum_data&#91;$j&#93;&#91;'forum_last_post_id'&#93; &#41;
							&#123;
								$last_post_time = create_date&#40;$board_config&#91;'default_dateformat'&#93;, $forum_data&#91;$j&#93;&#91;'post_time'&#93;, $board_config&#91;'board_timezone'&#93;&#41;;
								$last_post = $last_post_time . '<br>';
								$last_post .= &#40; $forum_data&#91;$j&#93;&#91;'user_id'&#93; == ANONYMOUS &#41; ? &#40; &#40;$forum_data&#91;$j&#93;&#91;'post_username'&#93; != '' &#41; ? $forum_data&#91;$j&#93;&#91;'post_username'&#93; . ' ' &#58; $lang&#91;'Guest'&#93; . ' ' &#41; &#58; '<a>' . $forum_data&#91;$j&#93;&#91;'username'&#93; . '</a> ';
								$last_post .= '<a><img></a>';
							&#125;
							else
							&#123;
								$last_post = $lang&#91;'No_Posts'&#93;;
							&#125;
							if &#40; count&#40;$forum_moderators&#91;$forum_id&#93;&#41; > 0 &#41;
							&#123;
								$l_moderators = &#40; count&#40;$forum_moderators&#91;$forum_id&#93;&#41; == 1 &#41; ? $lang&#91;'Moderator'&#93; &#58; $lang&#91;'Moderators'&#93;;
								$moderator_list = implode&#40;', ', $forum_moderators&#91;$forum_id&#93;&#41;;
							&#125;
							else
							&#123;
								$l_moderators = '&nbsp;';
								$moderator_list = '&nbsp;';
							&#125;
							$row_color = &#40; !&#40;$i % 2&#41; &#41; ? $theme&#91;'td_color1'&#93; &#58; $theme&#91;'td_color2'&#93;;
							$row_class = &#40; !&#40;$i % 2&#41; &#41; ? $theme&#91;'td_class1'&#93; &#58; $theme&#91;'td_class2'&#93;;
							$template->assign_block_vars&#40;'catrow.forumrow',	array&#40;
								'ROW_COLOR' => '#' . $row_color,
								'ROW_CLASS' => $row_class,
								'FORUM_FOLDER_IMG' => $folder_image,
								'FORUM_NAME' => $forum_data&#91;$j&#93;&#91;'forum_name'&#93;,
								'FORUM_DESC' => $forum_data&#91;$j&#93;&#91;'forum_desc'&#93;,
								'POSTS' => $forum_data&#91;$j&#93;&#91;'forum_posts'&#93;,
								'TOPICS' => $forum_data&#91;$j&#93;&#91;'forum_topics'&#93;,
								'LAST_POST' => $last_post,
								'MODERATORS' => $moderator_list,
								'L_MODERATOR' => $l_moderators,
								'L_FORUM_FOLDER_ALT' => $folder_alt,
								'U_VIEWFORUM' => append_sid&#40;"viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id"&#41;&#41;
							&#41;;
						&#125;
					&#125;
				&#125;
			&#125;
		&#125;
	&#125; // for ... categories
&#125;// if ... total_categories
else
&#123;
&#125;
// Generate the page
$template->pparse&#40;'body'&#41;;
include&#40;$phpbb_root_path . 'includes/page_tail.'.$phpEx&#41;;
karnaiss
Atbildes: 175
Atrodas: a vot
Post no karnaiss » 09 Apr 2008, 00:22
Vareji labak sito kkur uploudet, jo pa visu temu vins ir
esmu tikai cilveks
Atbildes: 1780
Post no Mr.Death » 09 Apr 2008, 09:27
Man nezkāpēc šķiet ka problēma būs ar iekļaujošajām iekavām pirms 285 rindiņas, jo tās nav noslēgtas. Pamēģini iemest kādas noslēdzošās
Code: Select all
&#125;
286tajā un apskatīties, ko viņš Tev tur izmetīs.
P.s. Tālāk papētot kodu man gan šķiet ka tur kaut kas ir aprauts, jo vesela čupa ar noslēdzošajām, kas it kā neko nenoslēdz.
Ernijs_E
Atbildes: 94
Post no Ernijs_E » 09 Apr 2008, 10:10
Es iemetu neko nemaina, teksts tas pats, errors arii, kautkas naw.
Atbildes: 5078
Post no foxsk8 » 09 Apr 2008, 13:33
Kodu liec šeit:
paste.php.lv
Kas attiecās uz modifikāciju, pameklē iekš tā saita, no kurienes ņēmi. Iesaku visu paņemt nost, uzlikt backup atpakaļ un lietot šo čata modifikāciju, kuru lieto notepads.
https://blueimp.net/ajax/
Atbildes: 2011
Post no deivs001 » 09 Apr 2008, 17:21
Foxsk8 nav labākais čats, jo uz Operu gļuko.
Atbildes: 5078
Post no foxsk8 » 09 Apr 2008, 17:44
deivs001 wrote:Foxsk8 nav labākais čats, jo uz Operu gļuko.
+1 , bet labāks par kaut kādu shoutbox.
Return to “PHPBB”
