Pirkt vai nē, iespējams citas alternatīvas. (laptops)
mmittz
Atbildes: 46
Pievienojies: 04 Jūn 2008, 10:41
Post no mmittz » 30 Jūn 2008, 20:57
ACER AS6920G 16"/T5750/4GB/BT/GF9500M GS
ATMIŠ…AS KOPNE: DDR2-667
ATMIŠ…AS SLOTI: 2
AUGSTUMS (cm): 4.36/3.93
BATERIJA: LITHIUM–ION 6-CELL
BATERIJAS KAPACITÄ€TE: 4400 mAh
BLUETOOTH: JÄ€
CACHE: 2 MB
CHIPSET: Intel 965PM
CIETÄ€ DISKA KONTROLIERIS: Serial ATA
CIETAIS DISKS (GB): 250 GB
DISPLĒJA IZMĒRS: 16
DISPLĒJS: TFT WXGA
DROŠ ĪBAS SISTĒMAS SAVIENOTÄ€JS: Pirkstu nospiedumu lasītājs, Kensington Lock slot
DZIĻUMS (cm): 27.5
DZIŠ…A VEIDS: DVD Super Multi drive (DVD-RAM, DVD±R/±RW)
EKRÄ€NA TIPS: CineCrystal
FAX/MODEM: 56K V.92
FIREWARE SAVIENOJUMS: NĒ
FLOPPY DRIVE: NAV DRAIVA
GALVENÄ€ ATMIŠ…A: 4096 MB
GALVENÄ€ ATMIŠ…A (MAX): 4 GB
IEBŠªVĒTS FLASH KARŠ U LASĪTÄ€JS: 6-in-1
INFRASARKANO STARU SAITE: JÄ€, CIR
INSTRUKCIJA VALSTS VALODÄ€: NĒ
INTEGRĒTS NIC: JÄ€
KLAVIATŠªRAS VALODA: EN
MAKS. IZŠ ĶIRTSPĒJA: N/A
MARĶĒTA PRECE: NĒ
NIC: 1 GIGABIT ETHERNET
OPERĒTÄ€JSISTĒMA: Windows Vista Home Premium
OPERĒTÄ€JSISTĒMAS VALODA: Angļu
PAPLAРINĀРANAS PORTI: S/PDIF, RJ-11, VGA-out, HDMI, Line Out, S-video, AC adapter, Infra-red, RJ-45, USB 2.0, CIR, Line In
PCMCIA-SLOTS: 1 EXPRESS CARD 54
PELE: TOUCH PAD
PIEEJAMIE ATMIŠ…AS SLOTI: 0
PLATUMS (cm): 38.5
PRIEKŠ ĒJÄ€ KOPNE: 667 MHz
PRIMÄ€RÄ€ VALSTS: Universal
PROCESORS: Intel® Core™ 2 Duo processor T5750
RPM: 5400 rpm
SKAĻRUŠ…I: N/A
SKAŠ…AS KARTE: Integrated 5.1 soundsystem
SPECIFIKÄ€CIJAS: 0.3M Webcam
SVARS (kg): 3.5
TAKTS FREKVENCE: 2.0 GHz
TV IZEJAS KONEKTORS: JÄ€, S-VIDEO
USB-PORTI: 4
VIDEO KARTE: NVIDIA® GeForce™ 9500M GS
VIDEO KARTES ATMIŠ…A: 512 MB
VIDEO KARTES ATMIŠ…A (MAX): 512 MB
WLAN: YES a/b/g/n
http://www.itpasaule.lv/portativie_dato ... gf9500m_gs
Atbildes: 3460
Post no msh » 30 Jūn 2008, 21:01
Tas ir acers :D
mmittz
Atbildes: 46
Post no mmittz » 30 Jūn 2008, 21:25
un paskaidro sīkāk ? :D
Atbildes: 3460
Post no msh » 30 Jūn 2008, 21:41
Labi, tas tā, prikola pēc :D Bet nu cik nācies saskarties ar fujitsu-siemens kastēm [un arī pāris porķikiem], tad ir labi, klusu un vēsi uztaisīts :)
[Tūlīt kāds atnāks un pateiks ka tas acers ir baigi labais :D ]
Atbildes: 5311
Post no shady » 30 Jūn 2008, 21:53
Labs laptops, kas tev msh nepatīk?
Atbildes: 3460
Post no msh » 30 Jūn 2008, 22:07
Labi, neko, lai veiksmīgi pērkas.
mmittz
Atbildes: 46
Post no mmittz » 30 Jūn 2008, 22:23
o sakat par video karti? kādu spēli pavilks ?
Atbildes: 3460
Post no msh » 30 Jūn 2008, 22:37
Ja tu taisies spēlēt spēles, par porķiku aizmirsti!
Kārtējais datora no vienas istabas otrā nēsātājs? :hmz:
Atbildes: 5080
Post no foxsk8 » 01 Jūl 2008, 00:11
Kā jau te vienā tēmā teicu, ja PC domāts darbam, bieži braukā, neesi uz vietas, tad ir īstais risinājums, bet ja jau doma ir uz spēlēm un vairāk laika pavadi mājas, tad droši ņem kādu galda datoru, kaut vai iekš m79.lv var ap 200 Ls salikt tīri pieklājīgu gamer PC.
P.S. Ja kaut ko pērku, es skatos, kas būs pēc gada, diviem. Ja tavs laptops, nedod dievs pēc garantijas laika aizies pie tēviem, remonts sanāks daudz reiz dārgāk nekā galda PC. Laptops, kāds nu tev viņš ir, tāds viņš tev būs visu laiku. Vienīgais labums, ka viņš ir maziņš un ērti pārvietojams.
marr
Atbildes: 569
Post no marr » 01 Jūl 2008, 00:35
Pilnīgi piekrītu shady.
No pieredzes ("uzraušanās") neiesaku HP paviljonus, ja pašam tagad būtu jāņem, tad ņemtu asus, kā rezerves variants tam būtu tieši acer (ja runa ir tikai par firmu).
Atbildes: 5080
Post no foxsk8 » 01 Jūl 2008, 00:38
Man tieši beigts HP Pavilion stāv, nevajag :D :D
marr
Atbildes: 569
Post no marr » 01 Jūl 2008, 00:39
manējais par laimi vēl velk (tfu, tfu, tfu), tiesa, arī garantija viņam vēl ir. Kaut gan kā jau ne reizi vien izbazūnēts - mātes plati jau paguvu nomainīt :D
Atbildes: 5080
Post no foxsk8 » 01 Jūl 2008, 01:47
MB pa garantiju mainīji vai pirki jaunu? Skatījos, lēts prieks tas nebija.
marr
Atbildes: 569
Post no marr » 01 Jūl 2008, 14:29
pa garantiju, protams :)
Return to “Video un Audio”
