Kādu mātesplati lieto?
Kas jums pat�k lab�k?
Poll ended at 28 Mar 2007, 22:23
Intel
8
47%
AMD
9
53%
Total votes: 17
Atbildes: 2873
Post no usins » 26 Feb 2007, 21:23
Vēlētos uzzināt kādas mātesplates tiek lietotas visbiežāk. Būtu labi, ja ieliktu arī mātesplates attēlu.
Piemēram man pagaidām ir DFI AD 73 Pro mātesplate.
Socket:A
RAM:Max 3GB
CPU:AMD
VGA:8x
PCI:5sloti
IDE:2
nemesis
Atbildes: 1
Pievienojies: 25 Feb 2007, 22:57
Post no nemesis » 03 Mar 2007, 09:04
abit AV8 3rd
Socket - 939
CPU /MAX - AMD 64 / 4800+
Ram / Max - DDR400 / 4GB
VGA - AGP 8x
PCI - 5x
IDE - 2x
8)
HardWare
TheNewGuy
Atbildes: 27
Pievienojies: 25 Feb 2007, 18:39
Atrodas: VIDZEME
Post no TheNewGuy » 04 Mar 2007, 11:14
ASUS A8V - EAYZ
BIOS: AMI
Chipset: VIA K8T800Pro + VT8237
CPU Interface: Socket 939
Max. CPU Support: AMD Sempron 3200+, AMD Athlon 64 4000+, AMD Athlon 64 FX-57, AMD Athlon X2 Dual-Core 4800+
Front Side Bus: 2000MT/s
RAM Technology: DDR (Dual Channel)
RAM Slots: 4 x 184-Pin
RAM Speeds: DDR266, DDR333, DDR400
Max. Memory Support: 4GB
Expansion Slots: 1 x AGP 8x/4x, 5 x 32-bit PCI, Storage Controller(s), 2 x IDE (ATA-133/100/66/33), 2 x Serial (ATA-150), RAID 0, RAID 1, JBOD
On-Board LAN : 1 x 10/100/1000
On-Board Audio: Realtek ALC850, 8-channel
On-Board Video
Back Panel I/O Ports: 1 x Parallel, 1 x COM, 1 x PS/2 Keyboard, 1 x PS/2 Mouse, 4 x USB2.0, 1 x Coaxial S/PDIF Output, 1 x LAN, 6 x Audio
Internal I/O Connectors: 2 x USB2.0, 3 x FAN, 1 x 20-pin ATX Power, 1 x 4 pin ATX 12V Power, 1 x CD Audio, 1 x AUX, 1 x Game
Form Factor: ATX, 305mm x 245mm
Special Features: AMD Cool 'n' Quiet Technology, AI NET, AI Audio
Package Contents: User's Manual, 2 x 1-port S-ATA Power Leads, 2 x S-ATA Data Leads, 2 x IDE Lead, 1 x Floppy Lead, Backplate, Driver CD
_LAIKS_
Atbildes: 5080
Post no foxsk8 » 06 Mar 2007, 17:07
Uz ðîs mâtes plates grieþas best.oo.lv
CPU - Socket 754 for AMD Athlon™ 64 and Sempron Processors
- Supports AMD's Cool 'n' Quiet Technology
- Chipset capable to FSB 1000 MHz (2.0 GT/s)
- Supports Untied Overclocking Technology
- Supports Hyper-Transport Technology
Chipset - NVIDIA® GeForce 6100 / nForce 405
Memory - 2 x DDR DIMM slots
- Supports DDR400 / 333 / 266
- Max. capacity: 2GB
BIOS - 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
Audio, Video and Networking
Graphics - Integrated NVIDIA® GeForce6-class graphics DX9.0 VGA
- Pixel Shader 3.0
- Max. shared memory 256MB
Audio - 7.1 CH Windows® Vista™ Basic Level HD Audio (ALC861VD/ALC883 Audio Codec)
LAN - Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
Expansion / Connectivity
Slots - 2 x PCI slots
- 1 x PCI Express Graphics slot
- 1 x PCI Express x1 slot
- 1 x HDMR slot
Connector - 2 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, JBOD), NCQ, and "Hot Plug" functions
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x COM Port header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O HD 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA Port
- 1 x Parallel Port (ECP/EPP Support)
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Hybrid Booster - CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories - Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 cables
- 1 x SATA data cable (optional)
- 1 x SATA 1 to 1 power cable (optional)
- 1 x COM port bracket
- 1 x HDMR card (optional)
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Form Factor - Micro ATX Form Factor: 9.6-in x 8.2-in, 24.4 cm x 20.8 cm
OS - Microsoft® Windows® 2000 / XP / XP 64-bit / Vista™ / Vista™ 64-bit compliant
Certifications - FCC, CE, WHQL[/url]
AIDSkillz
Atbildes: 183
Mana MB
Post no AIDSkillz » 07 Mar 2007, 00:38
1. Supports 800MHz FSB Pentium® 4 Processor with HT Technology
2. Supports Dual Channel DDR400 architecture
3. AGP 8X interface for excellent graphics
4. Integrated Serial-ATA interface
5. Realtek gigabit ethernet controller
6. 6-channel AC'97 audio with Jack-Sensing function
Edited by Usins- Man nebija slinkums :)
Atbildes: 2011
Post no deivs001 » 14 Mar 2007, 19:51
CPU
- LGA775 for Intel Pentium 4 / Celeron D processor
- FSB 800/533 MHz
- Supports Hyper-Threading Technology
- Support EM64T CPU
Chipset
- Northbridge: Intel 915PL
- Southbridge: Intel ICH6
Hybrid Booster
- CPU Frequency Stepless control
- AGP/PCI frequency fix
- ASRock U-COP
- Boot Failure Guard (B.F.G)
Memory
- Dual Channel DDR memory technology
- Supports DDR400/333
- DIMM slots: 2
Slots
- PCI Express x16 slot
- AGI Express slot (Default setting as PCI Express x 1, and can be adjusted to PCI Express x4)
- PCI Express x1 slot
- PCI slot x4
VGA - n/a
Audio - Realtek ALC850 8 channel AC'97 audio codec
LAN - Realtek RTL8101L 10/100 Fast Ethernet controller
- 802.3u, WOL supported
Connector
- 4 x Serial ATA 1.5Gb/s connectors
- 1 x ATA100/66 IDE connectors ( supports 2 x IDE devices)
- CPU/Chassis FAN connectors
- CD audio in header
- 2 x USB 2.0 header (to support 4 USB2.0 ports)
Rear Panel I/O ASRock 8CH I/O Plus
- 4 x USB2.0 ports
- 1 x RJ45 LAN port
- 1 x Serial port (COM1)
- 1 x PS2 Keyboard connector
- 1 x PS2 Mouse connectors
- 1 x Parallel port (LPT1)
- 1 x 8 channel Audio port ( Line In/Out, Mic In)
BIOS Feature
- 2Mb AMI BIOS with ACPI, SM BIOS 3.0, PnP
Support CD- Drivers, Utilities, AntiVirus Software
- 64 Bit Beta Driver inside
Accessories
- Quick Installation Guide, Support CD, I/O shield
- Floppy/ATA 100 cables
- 1 x SATA 1-to-1 power cable
Form Factor ATX, 305mm x 218mm
Certifications FCC, CE, MS WHQL
Atbildes: 2011
Post no deivs001 » 15 Mar 2007, 13:15
foxsk8 wrote:Uz ðîs mâtes plates grieþas best.oo.lv
Uz mâjas kompi turi best.oo.lv?
Atbildes: 5080
Post no foxsk8 » 15 Mar 2007, 13:32
Tas nav mâjas kompis. Tas ir serveris. Kurð atrodas mâjas. Kâpçc maksât lielu naudu. par hostinhu. Ja pats mierîgi varu nohostçt. Ja nu vienîgi serveris tiek noslogots ar winamp. Lai kaut ko citu darîtu izmantoju pârçjos datorus.
Atbildes: 2011
Post no deivs001 » 15 Mar 2007, 13:36
foxsk8 wrote:Tas nav mâjas kompis. Tas ir serveris. Kurð atrodas mâjas. Kâpçc maksât lielu naudu. par hostinhu. Ja pats mierîgi varu nohostçt. Ja nu vienîgi serveris tiek noslogots ar winamp. Lai kaut ko citu darîtu izmantoju pârçjos datorus.
Es jau nodomâju, ka serveris tev ari majas kompis.
Atbildes: 2873
Post no usins » 15 Mar 2007, 15:49
Nav jav tik stulbi tie best.oo.lv administratori (administrâcija):D
Vienîgi kkad jau bûs par svaku, priekð servera.. :)
Ja protams augs apmeklçtîba :)
no_name
Atbildes: 17
Pievienojies: 29 Mar 2007, 22:42
Atrodas: Centrs
Post no no_name » 24 Apr 2007, 23:40
Quanta 30B7 - informâciju meklejiet paði ;)
rajah
Atbildes: 730
Atrodas: Leišmale
Post no rajah » 27 Apr 2007, 16:05
dzhonsons
Atbildes: 820
Post no dzhonsons » 27 Apr 2007, 18:58
Procesors Amd Athlon 3000+ 1,8Ghz
Mâtene:
Asus M2NPV-MX [socket AM2]
Vairâk:
Form Factor ATX
Audio ADI AD1986A High Difinition Audio 5.1channel CODEC / Support Jack-Sensing and S/PDIF out interface
LAN NVIDIA nForce 430 built-in Gigabit MAC with external Marvell PHY
CPU Support AMD Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron/AMD Cool 'n' Quiet Technology/AMD64 architecture enables simultaneous 32-bit and 64-bit computing AMD Live! Ready
Front Side Bus 2000 / 1600 MT/s
USB Up to 8 USB2.0/1.1 ports
Expansion Slots 1 x PCI Express x16 / 1 x PCI Express x1 / 2 x PCI
Special Features ASUS Q-Fan / ASUS My Logo/ ASUS CrashFreeBIOS2/ ASUS EZ Flash 2
Chipset NVIDIA GeForce 6150 + nForce 430
Bios Features 4Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0
Storage/RAID South bridge: NVIDIA nForce 430 / *2 x UltraDMA 133/100/66/33 / *4 x Serial ATA 3Gb/s with RAID 0, RAID 1, RAID 0+1, RAID 5 & JBOD / NVIDIA MediaShield RAID 0, 1, 0+1, 5 and JBOD span cross Serial ATA drives
Memory Dual channel memory architecture / 4 x 240-pin DIMM, support max. 8GB DDR2 800/667/533 ECC and non-ECC,un-buffered memory
Enrike
Atbildes: 14
Pievienojies: 05 Mai 2007, 10:32
Atrodas: Neumunde
Post no Enrike » 07 Mai 2007, 22:25
http://www.abit-usa.com/products/mb/pro ... &model=205
Lietoju jau divus gadus, pretenziju nav, iisumaa sakot, kalpo ljoti uzticami, bez nekaadiem paarsteigumiem. Un, domaaju veel kaadu briidi arii ietrennet sjo maatiiti vistas eeraa...
Idiotisms ir universāls, jo to nevar izmērīt nevienā no vispārpieņemtajām mērvienībām. Heidingers
Ogijs
Atbildes: 32
Pievienojies: 29 Apr 2007, 08:17
Post no Ogijs » 13 Jūn 2007, 08:21
Procis - AMD Sempron 2500+ 1.4 GHz
Mātene - Biostar K8VGA-M
http://www.biostar.cn/Products/images/2 ... 756009.jpg
*nix powaah!
Tvinky
Atbildes: 454
Post no Tvinky » 13 Jūn 2007, 09:32
Pašlaik kaut kāda MSI, vecā - negribas pat info meklēt :)
Drīzumā taisos iegādāties šo:
Code: Select all
Īpašība 	Vērtība
NOSAUKUMS	ABIT S-AM2 NF590SLI DDR2 SATA2 GBL 8CH
KODS	AN9 32X-FATALLTY
RAŽOTÄ€JA KODS	AN9 32X-FATALLTY
EAN-KODS	4710933353888
RAŽOTÄ€JS	ABIT
PREÄŒU GRUPA	PAMATPLATES
PRIMÄ€RÄ€ VALSTS	Universal
DAUDZPROCESORU ATBALSTS	NĒ
CHIPSET	Nvidia Nforce 590 SLI
LIGZDA	SOCKET AM2
KOPNES ĀTRUMS	2000 Mt/s
DIMM SLOTI	4
MAKS. ATMIŠ…A (MB)	8192
ATMIŠ…AS KOPNE	DDR2-667,DDR2-800,
ATMIŠ…AS VEIDS	DUAL CHANNEL DDR2,ECC,non-ECC,UN-BUFFERED MEMORY,
INTEGRĒTA VIDEO KARTE	NĒ
INTEGRĒTS AUDIO	JÄ€
INTEGRĒTS NIC	JÄ€
IEBŠªVĒTS MODĒMS	NĒ
INTEGRĒTS SCSI KONTROLIERIS	NĒ
SKAĻRUŠ…U ATBALSTS	8 SKAĻRUŠ…I
IDE	SATA2 3Gb/p,ULTRA DMA/100,ULTRA DMA/133,
VIDEO KARTE	N/a
SATA KONEKTORI	6
RAID-CONTROLIERIS	RAID 0/1/0+1/5 JBOD
PCI SLOTI	1
AGP-SLOTI	0
AGP-Ä€TRUMS	0
PCI EXPRESS 1X	2
PCI EXPRESS 4X	0
PCI EXPRESS 8X	0
PCI EXPRESS 16X	2
PCI EXTREME	0
MINI-PCI SLOTS	0
CNR-SLOTI	0
AMR SLOTI	0
PARALĒLAIS PORTS	0
SERIAL-PORTI	0
PC/2-SAVIENOJUMI	2
USB-PORTI	4
FIREWARE SAVIENOJUMS	2
PLATUMS (cm)	24.5
GARUMS (cm)	30.5
NIC	2 * 10/100/1000 RJ-45
SKAŠ…U KARTE	7.1 CH HD AudioMAXâ„¢
SAVIENOJAMĪBA	FIREWIRE,RJ-45,USB,
SAVIENOJAMĪBA	PS/2
IEKŠ ĒJAIS SAVIENOTÄ€JS	Mic,Line,
Ä€RĒJAIS SAVIENOTÄ€JS	Line
INSTRUKCIJA VALSTS VALODÄ€	NĒ
MARĶĒTA PRECE	NĒ
CENA	Ls 128,50
Iekšā ligzdiņā iemitināšu šo:
Code: Select all
NOSAUKUMS	AMD ATHLON 64 X2 6000+ AM2 (125W) BOX
KODS	ADX6000CZBOX
RAŽOTÄ€JA KODS	ADX6000CZBOX
EAN-KODS	730143241427
RAŽOTÄ€JS	AMD
PREÄŒU GRUPA	PROCESORI
MARĶĒTA PRECE	NĒ
CENA	Ls 161,08
Atbildes: 5080
Post no foxsk8 » 13 Jūn 2007, 11:41
Tagad 3 dienas vecā plate man ir šāda. Vislielākais izbrīns man ir par 1GB integrēto video. ATI Radeon Xpress 1250. Ražotājs MSI.
CPU
• AMD® Athlon 64 X2, Athlon 64, Athlon FX and Sempron in the Socket AM2 package.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
FSB
• HyperTransport supporting speed up to 1GHz (2000MT/s)
Chipset
• AMD® 690V and SB600 Chipset
Main Memory
• Supports Dual DDR2 400/533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 4GB.
Slots
• 1 PCI Express x16 slot
• 1 PCI Express x1 slot
• 2 PCI slots, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by AMD® SB600
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 4 SATA II ports by AMD® SB600
- Supports storage and data transfers at up to 300 MB/s
RAID Function
- SATA II 1~4 supports RAID 0, 1 and 0+1 mode by AMD® SB600
MSI Reminds You...
• The RAID setup floppy disk is optional depending on the districts. You can download the files from the website to make the setup disk.
Audio
• Chipset integrated by Realtek® ALC888
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports 10/100 Fast Ethernet by Realtek 8101E (K9AGM2-L)
• Supports 10/100/1000 Fast Ethernet by Realtek 8111B (K9AGM2-F)
- ATX 24-pin power connector
- ATX 4-pin 12V CPU power connector
- CPU / System FAN connectors
- Chassis intrusion switch connector
- Front panel connector
- Clear CMOS jumper
- 1 X CD-in connector
- 1 X SPDIF out connector (optional)
- 1 X SPDIF in connector (optional)
- 1 x TV-out connector (optional)
- 3 x USB 2.0 connector support additional 6 ports
- 1 x Floppy disk drive connector
- 4 x Serial ATA II connectors
- 1 x ATA133 connector
MSI Reminds You...
• The floppy disk cable will be optional.
- 1 x Parallel port
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x 6 in 1 audio jack
- 4 x USB 2.0 ports
- 1 x RJ45 LAN jack
- 1 x VGA port
Dimension
• 24.4cm(L) x 21.5cm(W) Micro-ATX Form Factor
Mounting
• 6 mounting holes.
osh
Atbildes: 222
Atrodas: Belfast, NI
Post no osh » 13 Jūn 2007, 11:49
Return to “Aptaujas”
