DHCP servers lokālam tīklam .
remarco
Atbildes: 274
Atrodas: Riiga paarsvaraa
Post no remarco » 16 Sep 2008, 14:39
internets -----> tīklakatrte 1
tīklakarte 2 <-----> lokālais tīkls.
Nu un protams no lokālā tīkla jātiek internetā...
Uzliku dhcp serveri , nokonfigurēju itkā...
iisti nesapratu ja ieksh rc.conf
noraada dhcpd_ifaces="tiklakarte2"
vai jaanoraada kaut kas
ifconfig_tiklakarete2="???????ko te likt ?????" //mantagd staav DHCP, bet tas izklausas pretrunaa ar serveri ...
varbuut vispaar neko nevajag???
remarco
Atbildes: 274
Post no remarco » 16 Sep 2008, 15:05
# dhcpd.conf
# Sample configuration file for ISC dhcpd
# option definitions common to all supported networks...
option domain-name "remarco.esd.ktt";
option domain-name-servers 192.168.0.2, 192.168.0.1;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
authoritative;
# ad-hoc DNS update scheme - set to "none" to disable dynamic DNS updates.
ddns-update-style none;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
subnet 192.168.0.0 netmask 255.255.255.0 {
range 192.168.0.10 192.168.0.99;
option routers 192.168.0.1;
default-lease-time 86000;
max-lease-time 604800;
Te ir mans config fails.. iisti jau es vinju nesaprotu :((( ko tur esmu sadzejojis , bet nu ceru ka te kāds man var palīdzēt tikt ar to galā...
un rc.conf failaa es aizkomenteju rindiņu tai orai tiiklakartei uz kuru attiecas dhcp serveris.
Return to “Linux/BSD”
