Portatīvais dators ir izcili universāls, bez tradicionālajām Windows un Linux OS tam var "iebarot" arī Mac OS X.
Modeli MDT-130 ražo gan ar Atom, gan arī ar VIA C7-M754 procesoru.
Specifications (Intel Atom)
Processors: Intel Atom-N270 1600MHz
Operation system:Support Windows® XP/VISTA/LINUX/OS X
Memory:DDR2 1G
Storage Device:120G
LCD Size:13.3"LED LCD 1280*800
LAN: Realtek RTL8211/8212,10M/100M
WIFI: VT6656/100Mb/c/CDMA802.11a/b/g
Chipset: Intel 945GSE
Keyboard:U.S 82 key with embedded numeric keypad
Mouse&Touch pad:Touch pad, External USB Mouse
USB 2.0: 3*USB2.0 port
SD Card Compatible:SD/MS/MMC Card Reader
Build-in Camera:1.3M
Sound effect:In focus Audio,Build-in stereo speaker,Build-in Microphone
Battery:6CELL-2200MAH
Last time:6 HRS
Weight:1.6KG
Avots - mājaslapa
