Olympus jaunumi
Atbildes:14988
Atrodas:Liepājas anomālā zona
Olympus jaunumi
Post no samurajs » 19:58 / 10. Jan, 2009
[imgl]https://notepad.lv/userpix/28_fe45logo_1.jpg[/imgl]Viens no populārākajiem digitālās fototehnikas ražotājiem Olympus atkal iepriecina mūs ar 5 jauniem modeļiem. Trīs no tiem ir "lētā gala" kompaktkameras ( FE-5000, FE-3010, FE-45), divi - īpaši izturīgi, domāti piedzīvojumu cienītājiem (µ TOUGH-8000 un µ TOUGH-6000).
Jaunās kameras apgādātas ar uzlabotu seju atpazīšanas tehnoloģiju, Smart auto, attēlus var glabāt uz xD vai microSD atmiņas kartēm. Tradicionāli visiem Olympus modeļiem izvēlne ir arī latviešu valodā.
Olympus FE-5000
* Precision 5x optical zoom (36-180mm*) in a compact metal body to capture landscapes through to exciting close-ups
* Avoids blur thanks to Dual Image Stabilisation (combines mechanical and digital image stabiliser)
* The easy way to perfect images – Intelligent Auto Mode detects the five most commonly used scenes and adjusts settings, focus and exposure automatically
* Advanced Face Detection of up to 16 persons for perfectly focused and exposed faces
* 10 Megapixels to make prints up to poster-size
* See and share images more easily on the 6.9cm/2.7" LCD (230,000 dots)
* 14 shooting modes (e.g. Night Scene with Portrait and Smile Shot) ensure the camera has the right settings for different situations
* "One button, one function" design principle and in-camera help guide and for easy operation
* Liven up your memories with movie recording with sound (up to VGA resolution at 30fps)
* xD-Picture Card and microSD Card** compatible
Olympus FE-3010
* 12 Megapixels to make prints up to poster-size
* Miniature 3x optical zoom (36-108mm*) in a slim metal body to capture landscapes through to stunning portraits
* Digital Image Stabilisation for less blur
* 19 shooting modes (e.g. Underwater Wide and Fireworks) ensure the camera has the right settings for different situations
Olympus FE-45
* Miniature 3x optical zoom (36-108mm*) in a compact body to capture landscapes through to stunning portraits
* See and share images more easily on the 6.4cm/2.5" LCD (230,000 dots)
* 16 shooting modes (e.g. Night Scene with Portrait and Candle) ensure the camera has the right settings for different situations
Olympus µ TOUGH-8000
* Shooting in toughest situations – shockproof to 2m**, waterproof to 10m***, crushproof to 100kg**** and freezeproof to -10°C
* Available in Platinum Silver, Midnight Black, or Steel Blue
* High-precision 3.6x wide optical zoom (28-102mm*) to capture landscapes through to stunning close-ups even in extreme conditions
* Avoids camera shake and blurry images thanks to Dual Image Stabilisation (combines mechanical and digital image stabilisation)
* TAP Control Menu for great convenience also when wearing gloves
* 6.9cm/2.7" HyperCrystal III LCD for best ever preview even in brilliant sunlight and at extreme angles (230,000 dots)
* Face Detection for perfectly focused and exposed faces. In combination with Shadow Adjustment Technology, other main parts of the picture are also correctly exposed.
* Easy checking of air and water pressure thanks to on-screen manometer
* LED illuminator to lighten up underwater or macro sceneries
* (up to VGA resolution at 30fps)
* xD-Picture Card and microSD Card***** compatible
Olympus µ TOUGH-6000
* Shooting when it's getting tough, wet and cold – shockproof to 1.5m**, waterproof to 3m*** and freezeproof to -10°C
* Available in Lemon Yellow, Pure White, Arctic Blue or Sunset Orange
* Advanced Face Detection of up to 16 persons for perfectly focused and exposed faces. In combination with Shadow Adjustment Technology other main parts of the picture are also correctly exposed.
Avots 1, 2.
Atbildes:2311
Pievienojies:12:54 / 9. Jan, 2009
Atrodas:Jūrmala/Rīga
Post no RicoPico » 14:17 / 12. Jan, 2009
Ak... Jau tagad to ziepjutrauku izvēles klāstā var prātu zaudēt, mēģinot atrast sev piemērotāko, un te vēl pievedums! Briesmas...
Labs ziepjutrauks būtu tāds, ar kuru skrienot pustumsā, bez zibspuldzes varētu noķert ideāli asu attēlu bez trokšņiem. Vot tādu es tiešām nopirktu sev. :D
