Jaunā programma Parallels Desktop ļauj vienlaicīgi darbināt abas OS, pie tam arī vienā logā.
Vairākuzdevumu režīmu piemēri: rakstām E-pastu ar Outlook Express, vienlaicīgi rediģējot video ar Mac programmu iMovie vai arī strādājam ar Apple Mail un vienlaicīgi sekojam līdz hokeja mačam caur IE7.
Fragments no Parallels Desktop apraksta mājaslapā:
With Parallels Desktop for Mac, you can:
* Run your favorite Mac and Windows applications at the same time without rebooting
* Seamlessly connect to any network in both Mac OS and Windows using a shared network connection
* Achieve a high level of performance for Windows on your Mac by leveraging Intel technology - an industry leading solution available on Parallels Software
* Copy and paste items between your Mac desktop and your Windows desktop
* Quickly create multiple virtual machines by using the new Parallels Installation Assistant
* Create “Active†backups by using Parallels Desktop for Mac in conjunction with Parallels Compressor
* Achieve optimal virtual machine performance and reduce disk space by 50% or more with the new Parallels Compressor
Diemžēl Mac programmas nav freeware produkti, bet 15 dienu Parallels Desktop trial versiju var iegūt šeit: http://www.parallels.com/en/download/desktop/
Pilna informācija un PDF manuāļi: http://www.parallels.com/en/
Ekrānattēls:
"Ja Jūs jebkad esat vēlējies izbaudīt divas pasaules, tad tagad Jūs to varat - ar Mac."
