Uz doto bridi stabilie variablji un funkcijas ko var izmantot-
Code: Select all
$theme ///= aktivas temas nosaukums
$home ///= sakumlapa
$copyright ///= dooh...
$keywords ///= html meta
$description //= html meta
$title ///= html
$cmstime //= cms nix laiks
$authorized ///= true; ///Norada ka lietotajs autorizejies... ja true autorizets, ja false- nee.
$username ///= dooh...
$access ///= lietotaja limenis no 1 lidz 10. 1= users. Parejie amati attiecigi cms majas lapa galvenaja
$avatar ///= avatara adrese vai faila nosaukums
$avatarmode ///= internal vai external . pagaidam atbalstas tikai external (URL) , internal tiks pieslegts tad kad pabeigshu galeriju..
///////// Shamas var izmantot tikai izvietoshanai, no edit...
sidemenu(); /// = genere sanu izvelni pec admina iestatitas kartibas un noteikumiem.
mainmenu(); ///= top menu, tapati automatika.
adminsidemenu() ///= mhmh mhm..
adminmainmenu(); ///admina main kontroles menuuu...
smilesmain($text); ///= smaili moduljiem kas liekami root tb htdocs vai pubhtml, moduljos kuri atrodas modules/ vai savas mapes neizmantojas....
smilesnomain(text);/// moduljiem savas mapes vai modules
bbcode(); /// nav tak jaskaidro
gatavos zipus te metam, ja nu kads grib kko uzkjimeret kvai testa pec...
Ja veidojam modulju moduli ( krutu , smagu ar savu mapi)
sakam lapas ar
Code: Select all
require_once"../config.php";
define(''.$define.'', 1);
require_once"../$kernel/kernel.php";
$hmode = "modulanosaukumsbezvaitspeisiem";
include_once"../stili/$theme/head.php";
echo"<div><div><center><img> Modulja tituls</center></div>";
/////////////te maucam kontentu un ja vajag iemetam zipa css failu, tiks izaukts pie attieciga headmoda lai lieki neslogo browseru...
echo'<div>
</div>
</div>';
/////un beidzam ar
include_once"stili/$theme/end.php";
A mini-include modeljiem rakstam plain tekstu bez visa šitā un stilu css faila
