Ubuntu linux (GNOME) - izpl
- samurajs
- Administrators
- Atbildes: 14988
Pçc ubuntu instalâcijas uzreiz duras acîs burtu vizuâlâs nepilnîbas, fonti ir izplûduði, daþi ar zilu çnojumu utt.
Darboðanâs 'fontu' izvçlnç daïçji atrisinâja problçmu, bet tik un tâ pagaidâm Windows XP ir tâlu priekðâ.
Ko varçtu darît lietas labâ? nVidia draiveris itkâ uzlikts, varbût vajag LCD monitora draiveri kaut kâ iebarot (Kâ? Man ir oriìinâlais uz CD)
Varbût ðitais ir efektîvs? http://ubuntuguide.org/wiki/Ubuntu:Feis ... for_Feisty
Kaut kas lîdzîgs jau izvçlnç 'Fonti' ir, bet maz ko dod.
Varbût tâ tikai GNOME vaina?
- fatduude
- Atbildes: 99
- Pievienojies: 14 Mar 2007, 12:09
- Atrodas: tepat
hmm, diezgan interesanti, nekad neesu dzirdçjis un lasîjis par ko ðâdu,bet nu varbût tev varçtu lîdzçt ðis topiks, varbût ne gluþi tas ko vajag, bet ðo to izmantot jau var: http://www.howtoforge.com/sharp_fonts_gnome
Tikko Linux lietotâjs bçdâ, palîdzîba ðeit pati atskrien!!!!!
How to improve sub-pixel font rendering for Feisty
This will dramatically improve the appearance of fonts with respect to the default Ubuntu install. The patched libraries are built against Freetype 2.3.x (not currently in feisty) and include David Turner's sub-pixel rendering patches.
* For i386 add the following to /etc/apt/sources.list
deb http://www.telemail.fi/mlind/ubuntu feisty fonts
deb-src http://www.telemail.fi/mlind/ubuntu feisty fonts
* Add the key
gpg --keyserver subkeys.pgp.net --recv-keys 937215FF
gpg --export --armor 937215FF | sudo apt-key add -
* Packages you're about to upgrade are libfreetype6, libcairo2 and libxft2
sudo aptitude update
sudo aptitude install libfreetype6 libcairo2 libxft2
* After the install, you may want reconfigure font settings. The following settings work well: Native, Automatic, No bitmapped fonts.
sudo dpkg-reconfigure fontconfig-config
* Add the key
Nç, tas nav 7.04 iekðâ - savâdâk neviens nepiedâvâtu pievienot repozitorus un apgreidot. Uzinstalç, tad runâ. Es uzliku, man fonti vçl asâki palika.samurajs wrote:Valodja paldies - ðito es jau pçtîju... manuprât tas ir tas pats, kas iekð 7.04 jau ir iekðâ... vismaz saucas 1:1 vienâdi!
Kâ tâ var bût, ka atverot Notepad (u.c.) ar Operu - viss prîmâ, bet ar FF - izplûdis??? Dzçris neesmu! :party:
http://ubuntuguide.org/wiki/Ubuntu:Feis ... for_Feisty[/list]
Mans LG flatron L1952s ar labi râda tos fontus. Samuraj, laikam tavs monitors bija izstraddâts speciâla windai....
Neòem pierç, gan jau sameklçsim izeju. Tev tikai fonti izplûduði? Vai arî logu malas, apaïâð formas? Kâds tev modelis? LCD monitori râda neizplûduðu bildi, ja tie strâdâ uz optimâlas izðíirtspçjas, piemçram manam 19 collu LG tâ ir 1028x1024. Ja uzlieku mazâku izðíirspçju, fonti un citi grafiskie elementi liekas izplûduði.
- fatduude
- Atbildes: 99
- Atrodas: tepat
-kâ ar citâm grafiskajâm vidçm?? kde, xfce? arî tâds pats rezultâts?
-negribi iepostos skrînðotus, kâ izskatâs tev tie fonti, un kas tavuprât bûtu ideâli? varbût vienkârði tev kaut kâda hiperredze, un tu saskati to kâ nemaz nav..
-hmm, kâds tev vispâr monitors? itkâ jau mûsdienu linukðiem vajadzçtu suportot visus bilþrâþus
- samurajs
- Administrators
- Atbildes: 14988
Suns vinju zin par citaam graf.videem, bet lieta attiecas tikai uz fontiem. Lapu malas, grafika viss OK.
Screenshots noteikti buus, bet riit. Man uz darbeli shonakt.
Monis - parastais LG Flatron L1717s.
Un kaa piedabuut leeto populaaro printeriiti Canon Pixma IP1000 darboties??? Nav iemonteeta draivera prieksh shitaa, citus pretii nenejem!
Ja ar standarta iemontçtajiem draiveriem nekas nesanâk. Tad pameklç atbildi ubuntuforums.org. Jeb arî citur googlç. Iespçjams vispâr nepiedabûsi klât - tâdi tie printeru raþotâji, tikai vindaj pârsvarâ raþo. HP labs atbalsts, cik esmu manîjis, bet savçjo Lexmark nçsmu piedabûjis strâdât, bet arî centies stipri nçsmu
A uz kâdas izðíirtspçjas tu to darbini? Uz rekomendçtâs 1280x1024?samurajs wrote:Suns vinju zin par citaam graf.videem, bet lieta attiecas tikai uz fontiem.
Citâts no wikipçdijas:
Un nav vajadzîgi tur nekâdi draiveri - uz windas uzliku savçjâ LG draiverus, tad atðíirîbu necik nepamanîju....Ðíidro kristâlu displeji attçlu râda perfekti tikai to normâlajâ izðíirtspçjâ (tavâ gadîjumâ 1280x1024). Mçìinot lietot zemâku izðíirtspçju attçls parasti kïûst izplûdis vai stûrains.
Tavam iP1000 printerim http://www.sumardi.net/2006/08/24/ip100 ... or-ubuntu/
ja godîgi tad manam firefoxim uz ubunta ar kkas ar fontiem ar nau kârtîbâ, baigi bieþi naina izmçru pie refresh, kaut arî pie ff iestatîjumiem uzliku min font size 11 :hmz:
ðajâ paðâ forumâ pirms ielogojas râda kâdu 8 font size.. :duno:
Esmu http://datorvecis.lv
- samurajs
- Administrators
- Atbildes: 14988
Par ðo jautâjumu es kârtîgi painteresçjos - lieta tâda, ka Linuxam defaultâ ir t.s. 'smooth' fonti, kuri neizskatâs tik asâm kontûrâm kâ Windows 'crystal' fonti. Risinâjums - piemest Linux fontu mapç klât pierastos TrueType fontus (arial, verdana utt.) Tâ arî izdarîju, un tagad viss OK. Arî Firefoxam.
Kâ izdarît? Reku ir: https://notepad.lv/viewtopic.php?t=365
Es problçmu neredzu defaultajos fontos ;) Tâka laikam nekâ tur nemainîðu =) Cilvçki atðíirîgi ar savâm prasîbâm, ja nepatîk defaultie liec citus - Linux ir OpenSource tur var mainît ko vien tîk un kâ. Vari pat visu parrakstît, ja ir vçlçðanâs un idejas ;)samurajs wrote:Par ðo jautâjumu es kârtîgi painteresçjos - lieta tâda, ka Linuxam defaultâ ir t.s. 'smooth' fonti, kuri neizskatâs tik asâm kontûrâm kâ Windows 'crystal' fonti. Risinâjums - piemest Linux fontu mapç klât pierastos TrueType fontus (arial, verdana utt.) Tâ arî izdarîju, un tagad viss OK. Arî Firefoxam.
