Tā, skatos to EULA:
You may permit a maximum of ten (10) computers or other electronic devices (each a “Deviceâ€) to connect to the Workstation Computer to utilize the
services of the Product solely for File and Print services,
Internet Information Services, and
remote access (including connection sharing and telephony services).
The ten connection maximum includes any indirect connections made through “multiplexing†or other software or hardware which pools or aggregates connections.
Except as otherwise permitted by the NetMeeting, Remote Assistance, and Remote Desktop features described below, you may not use the Product to permit any Device to use, access, display or run other executable software residing on the Workstation Computer, nor may you permit any Device to use, access, display, or run the Product or Product’s user interface, unless the Device has a separate license for the Product.
Izskatās, ka mans gadījums pakrīt zem tā "remote access", bet varbūt arī nē. Wikipēdijā "Remote access" tiek skaidrots kā kaut kas līdzīgs kā VPN.
http://en.wikipedia.org/wiki/Remote_access
Kā Jums izskatās, SQL conekcija uz šo attiecas?
