Pamācība: BB5 - SIM unlock
Atbildes: 5070
Post no foxsk8 » 30 Mai 2007, 11:55
Tad nu lūk, neliela pamācība, tutoriālis, kā atkodēt jaunos mobilos tālruņus, kuriem ir bb5 kodējums.
Diemžēl pamācība angļu valodā.
Nokia BB5 Unlocking
Disclaimer
I did not write any of this information, it is summarized from various sources. I am not responsible for any damage you may cause to you, your phone, or your computer. Credit for most of this work belongs to Dejan Kaljevic and the various posters on gsmhosting.com
Read this entire page before trying to do anything. If you do not agree with these terms, just leave, I'm trying to do people a favour.
What is BB5?
BB5 is a software platform used by Nokia in its newer phones.
Which phones are BB5?
* Nokia 3250
* Nokia 5500
* Nokia 6125
* Nokia 6126
* Nokia 6131
* Nokia 6136
* Nokia 6233
* Nokia 6234
* Nokia 6270
* Nokia 6280
* Nokia 6630
* Nokia 6680
* Nokia 6681
* Nokia 6682
* Nokia 7370
* Nokia N70
* Nokia N71
* Nokia N72
* Nokia N73
* Nokia N80
* Nokia N90
* Nokia N91
* Nokia N92
* Nokia N93
* Nokia E50
* Nokia E60
* Nokia E61
* Nokia E62
* Nokia E70
How do I unlock them?
If your phone is older BB5, then Dejan Kaljevic, a renowned GSM expert, has released software solution. His solution works for the following phones:
* Nokia 6630 RAP3G v2.10E PA
* Nokia 6680 RAP3G v2.0E PA
* Nokia 6681 RAP3G v2.0E PA
* Nokia E60 RAP3G v2.20E PA
* Nokia E65 RAP3G v2.20E PA
* Nokia E70 RAP3G v2.20E PA
* Nokia N70 RAP3G v2.20 PA
* Nokia N71 RAP3G v2.20 PA
* Nokia N90 RAP3G v2.11 PA
* Nokia N91 RAP3G v2.20E PA
* Nokia N93 RAP3GS v2.0E PA
I have one of those phones. How do I unlock it?
You need
* Phone (SIM card removed!)
* CA43 or DKU5 cable (Original Nokia with 13 pins)
* Software (http://users.net.yu/~dejan/download/bb5.zip)
Instructions
1. Connect cable to computer and phone
2. Set proper COM cable (must be, between 1 and 9)
3. Download unlocker, run `install.bat`
4. Open file c:/bb5_unlocker/logs/bb5_unlocker.cfg with a text editor set proper COM port (1-9)
5. Run c:/bb5 unlocker/BB5logunlocker.exe
6. Turn phone on. While it is turning on, click READ PHONE. You should see "DONE"
7. Click MAKE LOG, a log will be created. This log is used to generate the codes. Wait until you see "DONE".
8. Log file is in folder LOGS. Start BB5_calc.exe to make the PSW file.
9. Press button SP UNLOCK and unlock your phone.
It didn't work!
Solution courtesy to_deal_with on gsmhosting.com
* - Phone off,
* - Connect the cable to phone anc pc (dku5, jaf, serial)
* - Open the program
* - Power on the phone
* - When you see Nokia on the screen, immediately press on Read phone!
Afterwards use BB5 Calc and then SP Unlock
This method has always been a success.
If I power on the phone first and let it start up completely, by inserting the cable phone says enhancement not supported and making log fails.
In this case, reconnect the cable and Press Write backup.
If writing backup succeeded, Just follow the method I wrote above. Tested on many N70.
In Dejan's words:
Be sure that my BB5 logger is installed properly with apropriate FBUS interface (DKU-5) or old clasic FBUS cable connected to standard COM port.
Start loger.
Once connected phone by FBUS interface to PC, press "Read Phone" button. If everything is ok, some data will be readed and displayed, otherwise check your connection, phone, cables, etc.
If logger shows message "SP Data IS corrupted" than you have phone that somebody played with it and destroyed field 308,1. So, you have to fix that field by sending that phone to official NOKIA repair centre!!!
If everything is OK you can press "Make Log" button. LOGER will create backup of field 308,1 and try to make LOG file. In that process, sometimes field 308,1 can be corrupted which can be checked by clicking again on "Read Phone" button.
NOW, if logger shows message "SP Data IS corrupted" than you just have to click several times "WR Backup" and "Read Phone" to check that is your phone is OK.
My phone is hardlocked. What can I do?
If you have already used all 3 attempts to unlock via keypad, but you have unlock codes from your carrier, you can use the program to input the codes.
1. In "c:\bb5_unlocker\psw" create a text file "aaaaaaaaaaaaaaa_BB5.psw" where is "aaaaaaaaaaaaaaa" enter your phones IMEI
2. Then in that created file enter in "#pw+bbbbbbbbbbbbbbb+c#" where is "bbbbbbbbbbbbbbb" is the unlock codes and where is "c" enter your logs level number (1-7).
3. Save the file
4. Use "SP UNLOCK" function
My phone is a BB5 phone, but not on the list of phones that can be unlocked with Dejan's software. What can I do?
If your phone is locked to Vodafone UK you can try this:
http://www.fonefunshop.co.uk/Unlocking/nokiabb5.htm
Or you will have to wait until the solution is released for free.
posted by David at 6:30 PM
Links
* Google News
* Edit-Me
* Edit-Me
Previous Posts
* Nokia BB5 Unlocking
Archives
* May 2007
Powered by Blogger
Subscribe to
Posts [Atom]
brivprac
Atbildes: 66
Pievienojies: 29 Apr 2007, 12:56
Post no brivprac » 16 Nov 2007, 01:45
raksts labs, tik biju jau lasījis. :)
gaddienā kādam nau aizķēries DKU5 kabelis? :money:
Atbildes: 5311
Post no shady » 18 Nov 2007, 16:46
Nu tik daudz jau varēja pārtulkot latviski...
Bez tam - likums par telefona atkodēšanu {kā pretlikumīgu darbību} ir jau pieņemts spēkā vai vēl nav?
Post no samurajs » 19 Nov 2007, 00:00
shady: laikam ar 1.janvāri. Tad arī nozagtos telefonus nekur nevarēs likt jo visiem operatoriem būs uzlikts par pienākumu bloķēt IMEI.
Atbildes: 5311
Post no shady » 19 Nov 2007, 00:22
samurajs wrote:shady: laikam ar 1.janvāri. Tad arī nozagtos telefonus nekur nevarēs likt jo visiem operatoriem būs uzlikts par pienākumu bloķēt IMEI.
Kāds te sakars ar zagtiem telefoniem?
Zagtiem tāpat nomainīs IMEi un miers.
Post no samurajs » 19 Nov 2007, 00:30
shady: ja IMEI ir flashā, tad viegli. Bet ja tas iededzināts čipsetā? Arī IMEI maiņa būs aizliegta, vairs nevarēs par piečuku aiziet pie meistara...
Atbildes: 5311
Post no shady » 19 Nov 2007, 00:47
Tiem kas zog - šāda problēma nepastāvēs.
Jā, lielajai masai tas būs apgrūtinošs process.
Creep
Atbildes: 1138
Post no Creep » 26 Feb 2008, 19:28
emmm ja driikst jautaat tad kur un kaa iisti tas com ports jaamaina? nav kabelis pie rokas lai notesteetu un pameeginaatu... vienk rakstu pamaaciibu un tukloju un lai tur iesuutiitu kur gribu jaabuut viegli saprotami uzrakstiitam...
Atbildes: 2011
Post no deivs001 » 26 Feb 2008, 19:40
Tu tulko šo rakstu vai kā?
Atbildes: 5070
Post no foxsk8 » 26 Feb 2008, 19:59
Piebildīšu, ka šis raksts var būt nepilns. Nav pārbaudīts, vai rakstā minētā info patiešām noder, lai atbloķētu mobilo.
Atbildes: 979
Post no Sid » 26 Feb 2008, 20:43
piebildīšu, ka pareizi ir unlock nevis tas tur..
Return to “Mobilie telefoni”
