Disable visi windows lietotāji.
normis_161
Atbildes:436
Pievienojies:00:01 / 31. Mar, 2007
Post no normis_161 » 21:28 / 22. Jūl, 2009
[align=justify]Tā kā man vajadzēja pārinstalēt vairākus dators, tad aiz intreses pēc gribēju uzzināt, kas notiek ja disable visus Windows lietotājus, respektīvi, ja šādi izdara:
Jūsuprāt, kas notika un vai to vispār var izdarīt? Atbilde uz šo jautājumu ir jā. Kad es biju tā izdarījis, tad nākošās windows ielādes es vairs nevarētu ielogoties sistēmā, kaut arī tu skaidri un gaiši bija rakstīts, lai izvēlos lietotāju jeb account ar kuru vēlos strādāt. Tā kā tāda vairs neviena nebija, tad es vairs neko nevarēju darīt. Ne es varēju ielādēties save mode, ne pašā sistēmā ar savu loginu. Pēc tam ķēros klāt vecajai mīļajai googlei, un caur googli sanāca atrast šādu atrisinājumu:
[align=justify]
Put your XP CD in, and boot from it, just go through Setup like you're resinstalling it except for one step. After you've pressed F8 to accept the agreement and you get to the part of installing, one of the options is Repair. Select R to repair. It'll copy files and eventually reboot. Do not hit any key to boot from the CD, you'll see Installing Windows. Watch the left hand side of the install screen. As soon as you see it say Installing Device Drivers, hit the keys Shift and F10 together. It'll take you to a command prompt.
At this point type nusrmgr.cpl (new user manager control panel I think is what it stands for - someone correct me if I'm wrong). You'll get a graphical screen to the user accounts. It'll probably say Guest is Off. Doesn't matter, on the left hand upper side, create a new account using a different name than administrator or anything you've created before and give it administrator access.
Once done, close that screen and type exit to exit the command prompt so setup can continue, just input your license number again and off you go. It'll automatically log you in since you're still in a workgroup mode. Once logged in, click on start, and right click on My Computer, then manage, go to Users & Groups, then Users and then right click whatever account you want to re-enable. Remember that the new account you had created doesn't have a password, so either log out and log in as administrator and delete or disable the temporary account you previously created or whatever you decide to do - just don't disable all accounts
Pateicoties šim man sanāca atrisināt problēmu, bet rodas jautājums vai nav gadījumā kāds efektīvāks veids par šo, lai varētu risināt šāda veida problēmu? Š oreiz es domāju recovory console. Gadījumā neeksistē kaut kāda komanda ar kuras palīdzību es varētu izveidot jaunu lietotāju?
sir_irius
Atbildes:448
Pievienojies:17:52 / 1. Jūl, 2008
Post no sir_irius » 21:49 / 22. Jūl, 2009
Cik man zināms, rekoverij sūds iet caur administratora akountu - ja esi to diseiblojis, tad vari iet uz poda. :)
Mad182
Atbildes:903
Pievienojies:15:16 / 14. Mar, 2007
Atrodas:Latvija
Post no Mad182 » 21:51 / 22. Jūl, 2009
Kaut kad instalējot ubuntu sanāca gļuks, ka instalācijas laikā netika izveidots lietotājs, savukārt tā kā ubuntu ir līks linukss, ar root tā pat ielogoties nevar, būtībā sanāca sistēma bez lietotājiem. tad nu nācās pačakarēties lai tomēr ielogotos kā root un uztaisītu lietotāju :D
kuukums
Atbildes:41
Pievienojies:13:39 / 22. Mai, 2008
Atrodas:1. kojas
Post no kuukums » 21:58 / 22. Jūl, 2009
Manuprāt, vislabākā atbilde tava atrisinājuma beigās :D
..., bet patīk!!
Atbildes:5391
Pievienojies:14:22 / 10. Mai, 2009
Atrodas:Ir
Post no Crow » 22:05 / 22. Jūl, 2009
Nahren pupās jādiseiblo Administratora konts, būtībā Windowiskais root analogs? Nu tā sacīt, Mērfija likums - ja to var izdarīt un tas ir galīgi garām, tad atradīsies kāds, kurš to izdarīs :D
Ä€... nu jā, sākumā ir rakstīts, ka "aiz intereses" :D
Дебилы, бл*ть...
Atbildes:1730
Post no izredzētais » 22:06 / 22. Jūl, 2009
hirens boot cd - password tools. var noņ emt paroles, diseblot vai atbloķēt jebkuru lietotāju :)
Return to “Off-topic”
