PHPBB2 ACP error
krisis32
Atbildes: 568
Atrodas: jurmala
PHPBB2 ACP error
Post no krisis32 » 01 Jan 2010, 18:36
Phpbb2 ACP (ADMIN CONTROL PANEL) errors kad mēģinu uzlikt/noņemt kādam MODERÄ€TORA statusu!
Code: Select all
Couldn't delete auth access info
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND auth_mod = 0' at line 3
DELETE FROM phpbb_auth_access WHERE group_id = AND auth_mod = 0
Line : 180
File : admin_ug_auth.php
koda saturs uz 180 līnijas:
Code: Select all
message_die(GENERAL_ERROR, "Couldn't delete auth access info", "", __LINE__, __FILE__, $sql);
Atbildes: 2959
Atrodas: Sigulda
Post no ob1 » 01 Jan 2010, 19:41
"DELETE FROM phpbb_auth_access WHERE group_id = AND auth_mod = 0 "
izlabo kļūdu šajā rindā. group_id = ?????
Return to “PHPBB”
