izdzeesti faili.
remarco
Atbildes: 274
Atrodas: Riiga paarsvaraa
izdzeesti faili.
Post no remarco » 18 Jan 2010, 19:12
sorry par arumziimeem. sen laikam savaa xorgaa neesmu ieskatijies.
Ir taada lieta ka izdzeesu /usr/share folderi
tagad man xterm lamaajas :(
varbuut ir idejas kaa dabuut atpakalj ?
pieleitoju komandu
rm -r /usr/share
vai var buut kaa izlabot to truukumu xtermam. lamaajas daudz un biezhi. saka ka nevar make komandas izpildiit.
piemeeram shaadi lamaajas .
remarco# portupgrade -a
** Makefile possibly broken: devel/ORBit2:
make: no system rules (sys.mk).
/usr/local/sbin/portupgrade:1469:in `get_pkgname': Makefile broken (MakefileBrokenError)
from /usr/local/sbin/portupgrade:623:in `main'
from /usr/local/sbin/portupgrade:614:in `each'
from /usr/local/sbin/portupgrade:614:in `main'
from /usr/local/sbin/portupgrade:588:in `catch'
from /usr/local/sbin/portupgrade:588:in `main'
from /usr/local/lib/ruby/1.8/optparse.rb:1310:in `call'
from /usr/local/lib/ruby/1.8/optparse.rb:1310:in `parse_in_order'
from /usr/local/lib/ruby/1.8/optparse.rb:1306:in `catch'
from /usr/local/lib/ruby/1.8/optparse.rb:1306:in `parse_in_order'
from /usr/local/lib/ruby/1.8/optparse.rb:1254:in `catch'
from /usr/local/lib/ruby/1.8/optparse.rb:1254:in `parse_in_order'
from /usr/local/lib/ruby/1.8/optparse.rb:1248:in `order!'
from /usr/local/lib/ruby/1.8/optparse.rb:1241:in `order'
from /usr/local/sbin/portupgrade:565:in `main'
from /usr/local/lib/ruby/1.8/optparse.rb:791:in `initialize'
from /usr/local/sbin/portupgrade:229:in `new'
from /usr/local/sbin/portupgrade:229:in `main'
from /usr/local/sbin/portupgrade:2209
vai shaadi
remarco# aterm
/libexec/ld-elf.so.1: Shared object "libjpeg.so.9" not found, required by "aterm"
remarco#
Palaizhot izmet sho...
Cannot read termcap database;
using dumb terminal settings.
vaardu sakot baigaa dimbaa:(((
macbeton
Atbildes: 3510
Atrodas: Libau
Post no macbeton » 18 Jan 2010, 23:08
Nu a ko tu gribi?
Š…em instalu un sāc instalēt!
remarco
Atbildes: 274
Post no remarco » 19 Jan 2010, 05:48
A es ta muļķis cerēju ka šis nebūs pirmais txt komentos ....
Par cik serveri turpina "itkā" strādāt bez problēmām tad ar pārinstalēšanu vel pavilkšu līdz būs laiks izdomāt reālāku risinājumu.
Domāju varbūt no cd var sabakstīt tos /usr/share... iedarbināt xterm vai jebkuru citu termināli un tālāk jau "djelo tehniki". tā gan vel neesmu darijis . tapeč mazliet baidos nograut vispār .
Atbildes: 2918
Post no Wuu » 19 Jan 2010, 10:33
Palasi error logu un lēnītiņām saliec visu atpakaļ.
viesic
Atbildes: 161
Pievienojies: 26 Jan 2009, 13:37
Post no viesic » 19 Jan 2010, 10:57
kāda tev ir freebsd versija? (apskaties ar: uname -a)
pie fiziskās konsoles (vai ar ssh) tiec klāt? kaut vai ar sh shellu?
teorētiski vari mēģināt trūkstošo sistēmu ieinstalēt pa jaunu (izmantojot sysinstall - custom instalation - distributions - custom - [x] base ; [x] dict ; [x] doc un [x] man ) protams, sākumā nobackupo svarīgus datus (vismaz /etc mapi) :)
jau instalētie softi (iekš /usr/local) paliks visi kā bija, tiem nekas nenotiks, ja protams neaiztiksi partīcijas/slices.
ps. portupgrade (un make) neiet, tādēļ, ka nav /usr/share/mk/sys.mk fails.
termcap dati arī atrodas iekš /usr/share, tākā atjauno vien to direktoriju un visam būtu jāiet.
aterm kļūda par libjpeg.so.9 gan kkāda dīvaina, tas libjpeg atrodas iekš /usr/local/lib/libjpeg.so.9.
remarco
Atbildes: 274
Post no remarco » 19 Jan 2010, 18:22
$ su
Password:
_su: Cannot open /etc/termcap.
_su: using dumb terminal settings.
remarco# uname -a
FreeBSD remarco.lv 7.2-RELEASE FreeBSD 7.2-RELEASE #0: Fri May 1 08:49:13 UTC 2 009 root@walker.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC i386
remarco# s
remarco# sysinstall
Error opening terminal: xterm.
remarco#
Nu te es atbildēju uz viesic jautājuumiem.
Tieku kastei fiziski klāt gan caur ssh .... te iekopētais txt no putty pa taisno iekopēts.:)
Laikam jau būs jāņem palīgā boot disks un jāmēģina pieinstalēt trūkstošais. Takā ieteici caur custom...
principā sākotnēji jau arī bija caur turieni instalēts :)
šodien gan nebūs laiks paeksperimentēt :( jāgaida līdz svētdienai ... ātrāk nesanāks.
Atbildes: 2601
Atrodas: LV
Post no aoma » 19 Jan 2010, 21:44
varbūt beidzot padomā, ja negribi maksāt, tad jārēķinās ar nelielām problēmām
viegls rokenrols pa radio
remarco
Atbildes: 274
Post no remarco » 19 Jan 2010, 22:02
Aber davai nesāksim :)))
Es serverīti uzturu tīri sevis izglītošanas vajadzībām un darbinu savu ūber blogu :DD
ķēpājos ar dažādām muķībām un vel tiko Quake 3 palaidu puikām kur paspēlēties , vel arī torrent serverītis ir ērtākai failu nosūtīšanai ja vajag vairākiem cilvēkiem . vārdu sakot "samoučka" esmu . Izdevumi arī ir , elektrības rēķins, domēniņi . Domāju ka uz win jau būtu format c ja Tu runā par win , varbūt Tu domāji ka man vajadzētu kādam maksāt par 100MB vietas uz servera ? Nu , nu , man te ir pietiekami vietas visam ko griabas uz doto mirkli un tas ka nogrāvu usr diru ir tikai manis paša līko pirkstiņu nopelns . Nu ko, no kļūdām mācamies.
Atbildes: 2601
Atrodas: LV
Post no aoma » 19 Jan 2010, 23:25
remarco, mans iepriekšējais koments izskatās patīrīts, nu neko, visu cieņu Tev un Tavam suņam.
Ja puikas nopietni ķeras, klāt, nekadu iebildumu
remarco
Atbildes: 274
Post no remarco » 20 Jan 2010, 05:48
aoma , Nu ja trīs gadi pie freebsd serverīša ir nenopietni tad es nemaz nezinu kas ir nopietni :))
Ir pa šo laiku kaudz literatūras izlasīts un viena pabieza grāmata :) bet no muļķībām jau anv pasargāts neviens , Īpaši muļķi:)
remarco
Atbildes: 274
Post no remarco » 26 Jan 2010, 18:26
Jūtu ka normāli man neatjaunot sys darbūbu... Nāksies vien darīt pa jaunu jau izdarītos darbiņus:(
Nekas , vismaz nāksies atcerēties kā tiek viss konfigots :Dd
Return to “Linux/BSD”
