Telefons ar WM, Wi-Fi, GPS par nieka 70ls
http://www.dealextreme.com/details.dx/sku.25045
Saaku apsveert shii telefona iegaadi. Gribeetu dzirdeet juusu domas un varbuut arii kaadam links noder un izdomaa pasuutiit.
No komentiem apakšā:
"The original windows Mobile 6.1 is not really touchscreen-friendly and has an ugly and small virtual keyboard.
¤ It seems that there is a problem with the touch screen at the extreme right of it: the vertical line is really hard to use. You can feel it when you try to use the windows scroll bar. Little bit annoying, but not a big thing. "
"-As this is a really powerfull phone, battery drains fast"
"2) It has some failures in the touch screen (the PDA interprets touching in some points as if it were other point sometimes).
3) The buttons are somewhat difficult to use (pressing the directional button upwards sometimes makes you press left & right too), but with the touch screen you will rarely use it."
Vienu brīdi arī metu aci uz viņu, bet pārdomāju .
Uzmanās, esmu dabūjis akmeni
Tas, ka vienam indiviidam taa gadiijies, nenoziimee, ka visiem taa ir.
Un par negliito WM: likshu virsuu SPB shellu, taakaa taa nebuutu probleema...
Pogas, pielauju, tika spiestas ar ziilona pirkstiem (man taadu nav), taatad arii tas netrauceetu (taapat cik biezhi tad shamaas izmanto).
P.S. Komentaarus un topikus apakshaa tam telefonam jau sen paarlasiiju...
- daGrevis
- Vecākais lietotājs
- Atbildes: 2343
- Atrodas: Rīga, Latvija
Man būtu bail tādu pirkt...
http://last.fm/user/daGrevis
http://ask.fm/daGrevis
http://dagrevis.lv/
http://dagrevis.lv/
