freebsd Kaut kaada kljuuda....
remarco
Atbildes:274
Pievienojies:15:11 / 13. Jūn, 2007
Atrodas:Riiga paarsvaraa
Post no remarco » 20:44 / 3. Okt, 2007
instaleejo da jebko no portiem peec briitinja izmet eror:(
un tajaa teikts ka tai programmai vajadziigaa lieta neesot symlinks un nevarot taalaak turpinaat.
jo shai versijai esot jaabuut sumlinkam.
porti ir updeitoti.
error code 1..
Atbildes:706
Post no azazul » 12:33 / 4. Okt, 2007
Būtu ļot vēlamas nedaudz vairāk. Iemet kādas pēdējās 20 rindas šeit http://rafb.net/paste/
Ar zīlēšanu, pūšļošanu un gaišredzību te neviens nenodarbojas.
remarco
Atbildes:274
Post no remarco » 15:16 / 4. Okt, 2007
===> Vulnerability check disabled, database not found
===> Found saved configuration for gimp-2.2.17,2
===> Extracting for gimp-2.2.17,2
===> Patching for gimp-2.2.17,2
===> Configuring for gimp-2.2.17,2
===> Installing for gimp-2.2.17,2
===> gimp-2.2.17,2 depends on executable: gimp-2.2 - not found
===> Verifying install for gimp-2.2 in /usr/ports/graphics/gimp-app
=> gimp-2.2.17.tar.bz2 doesn't seem to exist in /usr/ports/distfiles/.
=> Attempting to fetch from ftp://ftp.gimp.org/pub/gimp/v2.2/.
gimp-2.2.17.tar.bz2 100% of 12 MB 70 kBps 00m00s
===> Extracting for gimp-app-2.2.17,1
=> MD5 Checksum OK for gimp-2.2.17.tar.bz2.
=> SHA256 Checksum OK for gimp-2.2.17.tar.bz2.
===> Patching for gimp-app-2.2.17,1
===> Applying FreeBSD patches for gimp-app-2.2.17,1
===> gimp-app-2.2.17,1 depends on executable: gmake - found
===> gimp-app-2.2.17,1 depends on file: /usr/local/bin/intltool-extract - found
===> gimp-app-2.2.17,1 depends on file: /usr/local/libdata/pkgconfig/gnome-mime-data-2.0.pc - found
===> gimp-app-2.2.17,1 depends on executable: pkg-config - found
===> gimp-app-2.2.17,1 depends on executable: update-desktop-database - found
===> gimp-app-2.2.17,1 depends on file: /usr/local/libdata/pkgconfig/gnome-doc-utils.pc - found
===> gimp-app-2.2.17,1 depends on file: /usr/local/libdata/xorg/libraries - not found
===> Verifying install for /usr/local/libdata/xorg/libraries in /usr/ports/x11/xorg-libraries
/usr/X11R6 exists, but it is not a symlink. Installation cannot proceed.
This looks like an incompletely removed old version of X. In the current version, /usr/X11R6 must be a symlink if it exists at all.Please read /usr/ports/UPDATING (entry of 20070519) for the procedure to upgrade X.org related ports.*** Error code 1
Stop in /usr/ports/x11/xorg-libraries.
*** Error code 1
Stop in /usr/ports/graphics/gimp-app.
*** Error code 1
Stop in /usr/ports/graphics/gimp.
*** Error code 1
piedo nesanaaca man tur iemest iemetu te jo nav paaraak garsh sarakstinjsh.
principaa shaadu izmet uz visaaam lietaam ko censhos nop potiem instaleet.
shitais ir tikai piemeeram.
nevareeju aatrumaa iedomaaties ko vel uzinstaleet :)))
vaardu sakot peec portu updeita ir taada probleeminja tagad:((((
hmm es tiko iedomaajos varbuut sisteema nemaz nezin ka es esmu atjaunojis portus???
mok vinjai kaut kur savs saraksts staav???
ar failiem???
Atbildes:706
Post no azazul » 15:35 / 4. Okt, 2007
Kā tev šķiet.. vai šis teksts tur ielikts smukumam ?
Un ko tev parāda X -version[color] ?
remarco
Atbildes:274
Post no remarco » 15:56 / 4. Okt, 2007
X Window System Version 6.9.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: FreeBSD 6.2 i386 [ELF]
Current Operating System: FreeBSD .apollo.lv 6.2-RELEASE FreeBSD 6.2-RELEASE #0:
Fri Jan 12 11:05:30 UTC 2007 [email protected]:/usr/obj/usr/src/
sys/SMP i386
Build Date: 16 October 2006
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
raada shaadi...
nee nedomaaju ka taa rindinja par velti likta...
Atbildes:706
Post no azazul » 16:23 / 4. Okt, 2007
no bļins , ko tu tur atkal esi uzkompilējis.
kā tev izdevās atkal uzlikt Xorg 6.9 ?
remarco
Atbildes:274
Post no remarco » 17:13 / 4. Okt, 2007
azazul wrote:no bļins , ko tu tur atkal esi uzkompilējis.
http://fc02.deviantart.com/fs20/f/2007/ ... Kid618.gif
tas man sanaaca tapeec ka portus es atjaunoju peec tam kad biju xorg uzlicis.
raadaas ka viss divu dienu maratonns jaaatkaarto tikai porti jaapdeito pirms vissa ko instaleejju.
respektiivi pirmaa darbiiba cvsup un porti un tad tikai viiss paareejais...
vai arii ...
kas notiks ja es ielooshos no root un nelaidiishu xorg
un tad
uztaisiishu xorg uninstall vai kaa tur un tad atkal uzinstaleeshu no portiem..
hmmm brrr...
bet es vinju man shkjiet no pakaam liku...
baac saputrojos pilniibaa...
rrrr shiito visu tagad atkaartot..
baac.
ko saki?
kaa labaak dariit?
es tur meegjinaaju lasiit bet par cik angliski saprotu & un vel paaris vaardus tad
neko daudz tur nesapratu.
un respektiivi neko tur updeitot man nesanaaca.
nja.
Atbildes:706
Post no azazul » 17:30 / 4. Okt, 2007
Nu updeitot Xorg nav diezko vienkārši.
Lai nu kā, tev vienkārši nevajadzēja instalējot atķekšet lai tev automātiski uzstāda arī portu kolekciju.
Uzinstalē, uzliec cvsup, sataisi supfile'u, palaid updeitu, sāc kompilēt X'us. (uz normālas kastes .. 1-2h), pēc tam uzliex fluxbox+opera (vēl 1h) un sāc lietot kasti.
Firefox sākumā kompilēt nav laba doma, jo tas daudz laiku paņ ems.
remarco
Atbildes:274
Post no remarco » 18:29 / 4. Okt, 2007
Paldies liels...
taatad pie instalaacijas portus nelieku.
un tad kaa tu tur teici.
shaubos vai shodien man vairs tam buus speeka un laika.
buus jaziedo briivdiens.
par operu runaajot...
kaut kas man vinjaa nepatiik diemzheel
kaut kaa shkjiet ka pa daudz tur visa kaa...
vel vienas jautaajums.
ko labaak ar cietni dariit?
daliit vinju vai nedaliit?
es te nerunaaju par swap utt bet nu man 160gb
un es domaaju sadaliit 50 /100 aptuveni un tos 50 iedot sisteemai ar vissaam taam vinjas partiicijaam.
respektiivi divaas daljaas sadaliit pirms ir taa otraa dalja kur veido jau swap utt partiicijas.
vai vienkaarshi visu vivnjam iedot un tad lai barojas taa sisteema kaa vinjai tur patiik?
nu ceru ka uztveeri manu domu...
p.s. uz kastes cits os nestaavees.
uj un vel jautaajums...
tie ko tu man teici izmantot lai nenjemtos ar xinitrc, (tagad piemirsu kaa tur bija vinjiem triis burti vaarduu sakot)
tie shtrunti portos nav???
taa lai var uztaisiit grafisko loginu .
jo pie kastes neseedeeshu viens
Atbildes:706
Post no azazul » 18:39 / 4. Okt, 2007
nu es darītu tā:
Pirmā partīcija ( +/- 20GB ) - sistēmas partīcija
  • / 512MB
    /var 2GB [te glabājas datubāzes arī .. tā kā ņ em pēc savām vajadzībam]
    /tmp 1GB [ļoti aktīvi lietota failu sistēmas daļa, tādēļ ļoti ieteicams to atdalīt]
    /usr ~20GB [līdzīgi kā windai C: disks]
Otrā partīcija - datu glabātuve
  • /mnt/hdd viss_cik_palikaGB
Iespējams ka tev ar vajadzet datubazi glabāt uz otrās partīcijas, ja kaut ko nopietni dari. Tad to var vienkārši pielinkot zem /var
remarco
Atbildes:274
Post no remarco » 19:03 / 4. Okt, 2007
tas mnt/hdd tad kad sys gatavs?
nu tad kad viss kaartiibaaa?
to otru hdd jau citi varees redzeet? tie citi juzeri.
es gribu taa lai teiksim ktorrent tur pa taisno var mest visu iekshaa un visi juzeri lai var brrauzeet pa teim failiem...
Atbildes:706
Post no azazul » 19:52 / 4. Okt, 2007
tas kā tu to folderi nosauc nav svarīgi.
vienkārši mēģināju norādīt, ka labak ir neturēt ar sistēmu nesaistītos failus uz vienas partīcijas ka pašu OS.
failu un ierīāu tiesības varēsi norādīt šinī gadījuma izmantojot lietotaju grupas
remarco
Atbildes:274
Post no remarco » 19:59 / 4. Okt, 2007
aha , super!:)
klau a kaa iisti nokonfigureet to visu lai es teiksim
no sava portatiiva varu piesleegties pie taas kastes no jebkurenes un pacholeet kas labs notiek..
un vel kaa iisti ftp tur sakonfigureet lai no win var paarmest no neta kaadus vailus tajaa kastee....?
vai shos labaak jaunaa topikaa?
vienkaarshi tiikla lietas man vel ir galiigi tumsha bilde....
P.S. tomeer paarinstaleeshu shodien.
viss jau notiek vienu reizi jau atkal ar visiem portiem uzmetu...
tagad gan itkaa pateicu portiem nee....
neko jau tiko man pateica ka filesystem is full... baac.
es saliku kaa parasti cietni...
:DDDD tavas prognozes par instalaacijas laikiem bija stipri optimistiskas :DDDD
laikam jau ierakstot monteeshanas punktu nevajag lietot lielos burtus:DDDD
piemeeram Tmp :))))
laikam tur vareeja buut kljuuda....
juhuuuuu porti tiek ar cvsup veidoti :)))
gaidam kas taalaak:)
Atbildes:706
Post no azazul » 21:48 / 4. Okt, 2007
Tā. Vispirms izstāstīsu par jūzeriem un grupām, jo tam ir ciešs sakars ar to ko tu gribi panākt.
Tātad:
Jebkurai iekārtai un failam iekš NIX ir 9 pieejas tiesību parametri kas grupēti pa 3 : lietotāja tiesības , lietotāja grupas un visu. To visu var apskatī ar komandām ls -l vai ll. Piemēram
Code: Select all
lrwxr-xr-x   1 mefisto  mefisto      8 Oct  4 21:20 hdd -> /mnt/hdd
-rw-rw-r--   1 mefisto  wheel  13950 Sep 28 00:43 pkgs
drwx------   2 mefisto  mefisto    512 Sep 28 12:38 .ssh
drwxrwx---   2 root  mefisto    512 Oct  4 14:45 source
-rw-r--r--   1 mefisto  users     64 Oct  4 14:51 vajag.txt
Pirmais ieraksts ir simboliskais* links uz partīciju kas piemontēta citur.
Tad fails 'pkgs' , kas kuru es un visi wheel** lietotāji varu lasīt un rakstīt (read-write).. citi var tikai apskatīt (read).
Tālāk - direktorija , kurai varu piekļūt tikai es. Tur glabājas jūtīgi dati.
Ceturtā ir direktorija 'source' , kurā var darīt visu root's un manas grupas lietot (tātad tikai man jūzeris un root)
Piekto gan jau pats saprati.
____________
* symlink nav windows izpratnes shortcuts, bet drīzāk tā paša fiziskā ieraksta uz HDD cits vārds. tb, ja tu izdzēs simboliski linkotu failu, arī orģināls tiek izdzēsts
** wheel grupa ir defaultā advanced-user grupa , tikai wheel grupai piederošie var izpildīt komandu su
Tā kā tu drošvien gribēsi tikt pie root, tev ir jāizveido uz to spējīgs lietotājs (ar root lietotaju tu attālināti ielogoties nevar .. un būtu idiotiksi ja varētu).
Ieraksti komandu sysinstall un tālāk ej uz Configure > Networking un iekliec ķeksi pie sshd.
Tad ej uz User Management. Tur izveido grupu, ar tādu pašu nosaukumu kā tavam lietotājam. Tad veido savu lietotāju , kuram piešķir grupu kuru jau tu izveidoji, un pie Member groups to ieraksto wheel.
BTW, drošvien gribēsi kā Login shell noradīt /bin/csh vai /usr/local/bin/bash
Tagad izmantojot šo lietotāju tu varēsi izmantot su komandu (super user). Gan remote, gna iekš X'iem.
Ja tu atķeksēji sshd, tad pie nākamā restarta šis serviss tiks piestartēts ( to var izdarīt arī bez restarta, bet pārāk ilgs pisiens , imo).
Vēl tu varētu gribēt nelielu programmu kura saucās screen. Instalāciju atradīsi /usr/ports/sysutils/screen . Uzkompilēsies 2ās minūtēs (pakas šim te nav).
Izmantošana. No kāda lietotāja tu palaid komandu screen. Tad tev prasa nospies Enter, un tu vari darboties tālāk, itkā izmantojot šo pašu jūzeri. Lai aizvērtu programmu ir jānospiež ctrl+a un tad d (komandu atšifrējums - action : detouch ). Lai atgūtu iepriekš atvērto, jāieraksta konsolē screen -x.
Screen ir kā 'remote desktop' priekš konsoles.
Ja ir iepriekš tikusi atvērta no lietotāja, tad visi cilvēki, kas izmanto to lietotaju, var izsaukt šo komandu, un izmantot vienlaicīgi *.
__________
* iekš #pcbsd irc kanāla tas tiek praktizēts, kā Remote Assistence rīks, jo var redzēt visu ko dara 'palīdzētājs' un var neteikt root paroli, bet gan pats ievadīt to.
SSH izmantošana.
Izmanto bezmaksas programmu Putty (uz windas , jo nix tas ir jau integrēts terminālī) , vai SecureCRT (maksas). Lai pieslēgtos , ieraksti IP adresi (liekas lauks saucās 'hostname') un un pārliecinies vai ir atzīmēts SSH (port 22).
Tas liekas viss ... gandrīz vai raksts sanāca.
P.S. ir iespējams pieslēgties arī grafiskajai videi attālināti, bet sākumā tev tāpat tādas nebūs, un txt mode atstās vairāk resursus pašam PC, tādēļ ātrāk viss notiksies.
remarco
Atbildes:274
Post no remarco » 22:01 / 4. Okt, 2007
uh cik daudz sarakstiji :)))
paldies es to no taviem vaardiem pat vienkaarshaak sapratiishu.
vispaar man graamatinjaa par linux ljoti liidziigi sarakstiits
taa ir kaut kaada rokas graamata linux galvenajaam komandaam - liidziigas pat taadas pashsa.
tur ir arii aprakstiits bik par to pieju sisteemu..
bet iisti nesapratu.
un tagad vakara nagla.....
xorg kompileejaas no portiem un atkal kjuudas:(((
proces paartraucaas kaut kaadaa vietaa...
paarbaudishu vai vinjam nav ar vietu pobleemas , bet izskataas ka ne....
ko nu? mest virsuu no pakaam? vai meegjinaat turpinaat?
te fragments no https://notepad.lv/posting.php?mode=editpost&p=7568
FreeBSD kernelis tiek kompilēts no uz CVS (Concurrent Versions System) servera esošā izejas koda (source code). Lai to iegūtu ieteicams lietot aplikāciju - cvsup-wutout-gui. To iespējams uzinstalēt šādi:
cd /usr/ports/net/cvsup-without-gui
make install clean
vai arī
pkg_add -r cvsup-without-gui
Vēl nepieciešams supfails kuru var atrast lapā cvsup.free.bsd.lv. Katrai FreeBSD versijai atbilstošie faili ir :
* freebsd_5_supfile
* freebsd_4_supfile
Kad fails ir iegūts, izejas kodu iegūst sekojošu komandu
cvsup -L 2 supfile
Pirms komandas palaišanas ļoti ieteicams izlasīt koentārus šai failā un veikt atbilstošās izmaiņas.
sanaak ka man vajadzeeaj mekleet sup failu 6.2 reliizei?
es esmu apjucis....
kaa lai zin kas jau ir uzinstaleejies un kas nav?
kas straadaas un kas nee?
vai meegjinaat dabuut tagat uzinstaleetaaas daljas nost
nop vietas pietiek....
atsaakot pa jaunu insatlaaciju kljuuda turpat.....
un shoreiz bez rindinjas izlasiit kaut kur kaut ko:(((
un kljuudu izmet pie vblank.c:363 error:
subdirs error1
nu te pa visu ekraanu tamliidziigi txt...
beigaas
stop in /usr/ports/graphics/dri.
error code 1
stop in /usr/ports/x11/xorg
laikam taa iet tikai iesaaceejiem :DDDD
Tu neticeesi....
pkg_info | grep xorg
xorg-clients-6.9 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
NU BLJAAAVIENS KAA LAI TIEK NO VINJA VALJAAA??????????????
VINJSH IR PASPEEJIS UZLIKT 16 LIETAS...
peedeejaa sarakstaa ir virtual framebufer server....
ja tev ir xorg tu vari pacholeet kas vel pietruukst...
bet nu bez shii jau laikam nestraadaas:((((
jaameegjina nodabuut tas dranjkjis nost
nu vo nost vinju arii neavr dabut:(
pareizaak sakot kad jautaa xorg -version tad vinjsh nav uzinstaleets a pkg info atroda pakas...
Azazul paldies par Tavu pacietiibu mani papmaacot un palabojot, bet tuvaakaas divas dienas man nebuus laika nonjemties..
turpinaasim sveetdien.
ja Tev vel ir idejas kaa man iisti tikt pie xorg versijas kas ir jaunaaka par 6.9 luudzu iemet man te, lai sveetdiena tsaakot nonjemshanos vareetu beidzot visu kaa naakas izdariit.
un vispaar man nevajag panjemt kaadu jaunaaku boot ? nevs 6.2 ?
teiksim nevis stable bet kas tur tagad jaunaakais?
jaabrien buus pacholeet :)
ok velreiz Tev paldies.
Atbildes:706
Post no azazul » 22:15 / 4. Okt, 2007
Tajā ko tu tur citē ir itkā rakstīts ar domu par kerneļa kompilēšanu (ja tev ir nvidia karte, tad tev patiesība arī kerneļa sourci vajadzēs, bet pašam ar to nekas nebūs jādara , to prasa nvidia draiveri, ja kompilē to no portiem).
Anyway, es taāu tev jau uzrakstīju
https://notepad.lv/viewtopic.php?p=7499#7499
remarco
Atbildes:274
Post no remarco » 21:38 / 5. Okt, 2007
aa, nu tad es kaut ko tur paarpratu.
jaa es jau dariju taa kaa tu teici ja kas, bet nu tas viss izmeta to ko es te ieprieksh samurgoju.
respektiivi lai nu kaa bet jaunaakus xorg vinjsh no portiem nekompilee :(
ok pagaidaam tad man ir skaidrs kas man jaadara un kas jaapanaak un tad jau kad tikshu ar shiim probleemaam galaa , skatiishos kas man taalaak sagaadaa probleemas.
JAAAAAA!!!!!! beidzot atradu kljuudu...
kaa jau iesaaceejs instaleejos kaa jau iesaaceejiem pienakas pa vienkaarshaako ieteikto celju.
respektiivi izveeloties
standart instalaaciju.
kad izveelas pakas no instaleet pateicu all un portus nelikt..
shinii briidii arii ir kljuuda jo xorg jau tiek atziimeets:(
vieniigi nav saprotams kapeec pie uznstaletas sys izpildot komandu whereis xorg neko neatrod????:(
taa nu es tagad njeemu un pateicu uzlikt minimal.
respektiivi nevienu citu paku iznjemot bin.
un vel viena tur bija kas ir vajadziiga .
liekam cvsup taisam supfailu un voalja xorg 7.x.x.x. un blablabla no portiem liekas ideaali :))))
super paldies azazul par helpu:)
rokjeles man ir liikas izraadas:)
bet nekas, pateicoties taam buushaaam nebuushanaam, daudz ko uzzinaaju un tagad lasu vienu graamateli lai zinaatu vairaak par siikuminjiem kas man galiigi nav skaidri:)))
vaardu sakot ciiniishos tagad ar visu paareejo un ceru ka naakamreiz uzdotie jautaajumi buus gana saturiigaaki un sakariigaaki.
PALDIES! :)
Return to “Linux/BSD”
